How To Anchor A Really Short Sill Plate Section To Slab? - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Nealtw
  • 1 Post By HenryMac
Old 12-13-2018, 10:55 PM   #1
Rewards Points: 18
how to Anchor a really short sill plate section to slab?
Hi All,
I am adding an addition to my home.One of the new walls extends from an existing wall and will have an exterior door within 8-12 inches of the old wall.
Code requires that the anchor bolts that hold the sill plate down to the slab be: 1) one within 12 inches of each end; 2) more than 3-1/2 inches from the ends, and; 3) at least two bolts per section.
If my wall and sill plate section is only 8-12 inches before the door rough opening, the requirements above are impossible. I can put one bolt in the middle of an 8 inch span at 4 inches, or I can put two bolts basically right next to each other at 3-1/2 inches from each side which would leave only about zero to 3 inches between them.
Is there some exception to code that allows just one anchor in such a small section (shown at bottom right of picture)?
Thanks.
Mogli is offline   Reply With Quote
Old 12-13-2018, 11:42 PM   #2
retired framer
Rewards Points: 1,654
Re: how to Anchor a really short sill plate section to slab?
I would cheat the one that is closer to the old wall and get the distance between them.
This is more about security for the door than anchoring the wall.
Old 12-14-2018, 12:05 AM   #3
JUSTA MEMBER
Rewards Points: 384
I would add Construction adhesive to neil's remedy, just to do it.
ED
You'd think by now that I would remember how to spell Nealtw.
Make that PL construction Adhesive.
de-nagorg is online now   Reply With Quote
Old 12-14-2018, 12:06 AM   #4
retired framer
ED
Sill gasket???
de-nagorg likes this.
Old 12-14-2018, 06:46 AM   #5
Rewards Points: 264
I think you can fudge where code conflicts with existing situation. Also smaller means not as essential to the structural integrity. Connecting the new wall to the old is also done with the wall studs as well. Don't just depend on the connection to the foundation, as with the sill plate. You don't want the sill to somehow move, so just use 2 maybe 4-5" apart? Don't crank down on the small piece of lumber since it could split.
carpdad is offline   Reply With Quote
Old 12-14-2018, 07:36 AM   #6
Rewards Points: 7,106
I'd also choose a piece of PT that has some nice knots, they do not split easily.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 12-14-2018, 08:36 AM   #7
HenryMac's Avatar
Rewards Points: 1,002
I'd suggest a standard anchor and a Simpson A-34 angle bracket attached with structural screws to the existing wall structure.
That will ensure the short sill section will be a very secure section.
https://www.homedepot.com/p/Simpson-...-A34/100375340
how to Anchor a really short sill plate section to slab?-mogli.jpg   how to Anchor a really short sill plate section to slab?-simpson-strong-tie-joist-hangers-a34-64_1000.jpg
MTN REMODEL LLC likes this.
HenryMac is offline   Reply With Quote
Old 12-14-2018, 11:00 AM   #8
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 308
Impossibiities or conflicts do sometimes arise with codes......
We had a very similar issue in Cali..... our thought was that code wanted 3.5 (4" in our case as code is 7 x anchor diameter with 5/8 J's) to prevent end splitting, but also wanted sill secure.
We were new to the inspector, so we actually ran down to the office.... asked if we could just go 2" from the ends.... said sure.
There is nothing magical about 7xbolt diameter from the end.... and I think if you have logic applied in those instances , as in the above posts suggestions, an inspector would have no problem with the solution.
With all the earthquake considerations and fastening issues in Cali, we ran into other minor framing conflicts also..... often adding some simpson A-35s or other to compensate.
MTN REMODEL LLC is offline   Reply With Quote
Old 12-14-2018, 03:07 PM   #9
Rewards Points: 18
Thanks. I'll go with HenryMac's suggestion on the plans and see what the city says. Can I put a stud on top of the corner bracket?
Old 12-14-2018, 10:09 PM   #10
Contractor/Engineer
Rewards Points: 1,138
Drill and install two redheads and bolt it down. Yes, you can put them close to each other...
Domo is offline   Reply With Quote
Old 12-14-2018, 10:13 PM   #11
HenryMac's Avatar
Use 1-1/2" Simpson Structural Screws... that'll be hell-for-stout.
https://www.homedepot.com/p/Simpson-...R100/202071152
Old 01-11-2019, 01:48 PM   #12
Rewards Points: 18
HenryMac, in your sketch, wouldn't I have a stud (or maybe even a double stud) where you show the angle bracket? FYI, this is butting the end of a new exterior 2x6 stud wall to what is currently the corner of an existing exterior wall, extending the wall. i.e., butting end-to-end, not making a "T" or "L".
I am wondering if I need a double stud at the end of the new where new meets meets old.
Old 01-11-2019, 01:55 PM   #13
JUSTA MEMBER
Rewards Points: 384
Yes treat it like an entire new wall, which it is.
ED
Old 01-13-2019, 09:04 AM   #14
HenryMac's Avatar
For the minimal cost of an extra stud.. Yes, I agree with de-nagorg.
The Following User Says Thank You to HenryMac For This Useful Post:
de-nagorg (01-13-2019)
Leveling products that won’t shatter when drilled into for sill plate attachment uncreative_user Concrete, Stone & Masonry 1 11-28-2017 08:11 PM
1910 Beach Bungalows: Replacing all joists & subfloor on imperfect sill plate alheim Building & Construction 7 04-14-2015 08:43 AM
Exterior wall sill plate not sitting on slab deno085 Building & Construction 16 09-30-2011 08:02 AM
Filling Gap between sill plate and slab DaveTile Carpentry 1 04-13-2011 04:52 PM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 09:08 PM
