House Overrun By Cats? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-21-2010, 11:58 PM   #1
House overrun by cats?
I am considering purchasing a home that the owner said was uninhatible --- because it was taken over by cats for a few years (yuck) i havent been inside but before i do --- i want to know is it possible to repair such a home or does it need to be demolished and rebuilt? thanks,
55redlady is offline   Reply With Quote
Old 05-22-2010, 02:02 AM   #2
You would likely have to get in there and see for yourself. I would suggest going on a really hot day as that will be when the house will be at it's funkiest. Cat scratching damage should be easy to repair. Cat feces fairly easy to clean up, Cat pee.... not so much.
Troglodyte is offline   Reply With Quote
The Following User Says Thank You to Troglodyte For This Useful Post:
55redlady (05-23-2010)
Old 05-22-2010, 08:31 AM   #3
Some houses like this are condemned by the Board of Health
No way to tell without seeing the damage
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 05-22-2010, 09:30 AM   #4
Military Mom of 4
Snav's Avatar
Well, if the house was unoccupied. Well, occupied by cats. Then you have these things to think of:
Mites - they live on animals and once the animal dies they seek out a new host.
Fleas - they live on animals, as well, but also survive quite comfortably without animals in hibernation (their eggs do, at least).
Urine and Feces - urine of all critters calcifies over time. Meaning that the area will always smell like it no matter what.
Doubtful that the cats did serious physical damage to the home (dogs usually do, though) but exposure to the elements (rain, snow, heat) always does a number.
So. . .it might be possibel to gut it down to it's bare bones and rebuild - treat for fleas and mites and bring it up to a good standard of habitation. But that will take a lot of money and a lot of time.
Might be cheaper to find another slightly more costly to purchase but less to rejuvenate home
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
The Following User Says Thank You to Snav For This Useful Post:
Old 05-22-2010, 09:36 AM   #5
My last house they had cats ....and no litter box
Carpets were all tossed, house fumigated 2x
I would enter, open doors & windows
Outside to breathe, re-enter & put fans on/in the windows for 15-20 minutes
Then I could go inside to work
Drywall was Ok, I did rip the main room walls to the studs to redo
I also eventually gutted & redid the kitchen 100%
All floors were either ripped up to the joists (kitchen & bath), or sanded down with a large drum sander
I spent ~17 days cleaning it before I moved in
Lots of deodorizers/renuzit - the ones you plug into the wall, plus solid ones
But after sanding & staining floors, painting etc you could not smell cat...even on a wet day
Old 05-22-2010, 10:49 AM   #6
firehawkmph's Avatar
Rewards Points: 2,586
Years ago I used to work with a remodeler and we renovated houses for a local realtor, including some where cats had there way. Toss all the carpet, clean up any mess. Fumigate the house for bugs like already mentioned. Then we would paint everything, walls, ceilings, floors that were getting carpeted, etc. Treat the house like it had a fire and seal everything with paint to get rid of the smell. Then start putting the house back together.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Old 05-22-2010, 08:34 PM   #7
Registered User
Termite's Avatar
I've seen a few of these homes over the years and in a few cases the pee has penetrated the subfloor. Nothing will ever get that out, other than replacing the subfloor. Personally I'd run like hell. Nothing will ruin a home (permanently) faster than a bunch of cats.
The Following User Says Thank You to Termite For This Useful Post:
Old 05-22-2010, 09:32 PM   #8
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 972
It's not just the floors. Ask a vet. A tomcat can spray the ceiling.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Old 05-23-2010, 04:41 AM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 2
Mike Hawkins
One word, BIN
Old 05-23-2010, 12:02 PM   #10
Rewards Points: 972
Most of those sealers like Kilz, are basically just shellac, only shellac is cheaper.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
New house drywall DISASTER pharm07 Off Topic 13 03-25-2011 02:24 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 10:01 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
