House Lifting 1940 Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 09:11 PM   #1
house lifting 1940 construction
I have to lift a 1940 constructed house, approx. 33 x 32 ft with no floor or joists. The walls are constructed of 4 inch x 8 foot long tamric timber, vertically installed. the floor and joists are completely rotten. The home has 2 walls inside running as load walls, same construction 4 inch tamric timbers on the vertical, creating a plus sign [ + ] inside. Any suggestions on raising all walls off the existing floor? The home is sitting on an 8 inch thick grade beam by 4 feet high, no footing.
Last edited by R Hirschfield; 09-21-2010 at 09:17 PM. Reason: correcting errors on information
R Hirschfield is offline   Reply With Quote
Old 09-21-2010, 09:16 PM   #2
Rewards Points: 474
Do you do this for a living? This is definitely not a DIY project.
Jim F is offline   Reply With Quote
Old 09-21-2010, 09:36 PM   #3
Are you trying to raise this house to move it or only high enough to put a foundation or rebuild the floor?
What type of roof and shape?
eastside is offline   Reply With Quote
Old 09-21-2010, 09:39 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,371
My crew and I did this very thing a good number of years ago to a house built in 1841. I can tell you it is very nerve racking not to mention very very slow and costly. It would be cheaper to hire some house movers to come out and raise it for you than to do it with hired help. This is JMHO.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
jlhaslip (09-22-2010)
Old 09-22-2010, 12:30 AM   #5
jlhaslip's Avatar
Rewards Points: 708
I'd second that...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Foam Board on exterior of above grade house Sheldon General DIY Discussions 6 12-08-2009 04:05 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
