Holes In Joists - Rules? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-14-2016, 03:47 PM   #1
Rewards Points: 86
holes in joists - rules?
rules seem comoonly known for sawn lumber
but for engineered wood, it (IBC) says to look at mfg sepcs.
am i mistaken, or does it look like most LVL mfg's are saying to stay IN the middle 1/3 for the location of holes? this seems opposite of the rule for sawn lumber....
odie91 is offline   Reply With Quote
Old 04-14-2016, 11:23 PM   #2
Rewards Points: 1,036
Re: holes in joists - rules?
Usually one would be using "LvL" for beams and the general rule for drilling holes in beams is do not drill period end of discussion. The only way you will be allowed to drill a LvL beam is if you have an engineer sign off and stamp the plan.(even if the manufacture allows drilling in certain places its likely your local code enforcement official will raise hel! if they catch it.)
Mingledtrash is offline   Reply With Quote
The Following User Says Thank You to Mingledtrash For This Useful Post:
Msradell (04-15-2016)
Raising toilet flange (tiled floor); bought Set-rite; screw holes don't line up lazzlazz Plumbing 12 09-12-2017 08:59 PM
Sistering joists or alternative Jaybone104 Building & Construction 13 09-15-2015 08:23 AM
1910 Beach Bungalows: Replacing all joists & subfloor on imperfect sill plate alheim Building & Construction 7 04-14-2015 08:43 AM
Strengthening Joists Before Basement Finish braverichard Building & Construction 16 06-20-2010 08:28 PM
making holes in the joists to run pipe christy123 Plumbing 5 01-20-2007 04:05 PM
