Hole Around Conduit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2015, 08:21 PM   #1
Rewards Points: 353
Hole around conduit
Wife backed into supply from street. Electricity is fine but need to patch/cover this hole.
Should I just use a bunch of silicone or is there another recommendation out there?
Zamboknee is online now   Reply With Quote
Old 07-02-2015, 09:16 PM   #2
Rewards Points: 1,742
If it is mechanically stable in that position, I would use a decent paintable caulk like DAP Alex Ultra or OSI Quad and then paint over it in a couple of days.
ChuckF. is offline   Reply With Quote
Old 07-02-2015, 09:50 PM   #3
Dave Sal's Avatar
Rewards Points: 940
It looks kind of big to just fill with caulk. I would first stuff some foam backer rod in there and then finish off with silicone caulk, preferably in a matching color.
Dave Sal is online now   Reply With Quote
Old 07-02-2015, 11:27 PM   #4
Rewards Points: 353
Like this? http://t.homedepot.com/p/MD-Building...1480/202066515
Old 07-03-2015, 06:17 AM   #5
Rewards Points: 17,868
I'd also just use paintable caulking.
Looks like there's not enough room to use foam cording.
Old 07-04-2015, 09:34 AM   #6
Household Handyman
Rewards Points: 1,412
It appears that around the top area of the hole itself there has previously been some type of caulk/sealant used. I'm with Dave Sal on this one. Use some backer rod and a quality caulk. You do not want any water intrusion on this type of siding.
Weep Hole in Conduit LChabbs Electrical 10 08-27-2014 08:39 PM
Buried gas pipe in conduit WillK Plumbing 4 01-07-2011 12:50 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 01:46 AM
Water in conduit MYSTERY feign3 Electrical 4 03-14-2010 08:17 AM
Deadbolt too large for deadbolt hole in frame? wysiwyg6000 General DIY Discussions 2 01-01-2010 10:06 AM
