Hip Roof Framing - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree9Likes
Old 02-25-2018, 05:49 PM   #16
Rewards Points: 504
Re: Hip roof framing
Some images. I googled hip roof details, then click on images. It shows ceiling joists necessary. If no ceiling joists, other way of bracing the rim joists. Doesn't have to be like the images but any roof framing must account for the load.
carpdad is offline   Reply With Quote
Old 02-25-2018, 05:58 PM   #17
jlhaslip's Avatar
Rewards Points: 708
I took too long typing my reply and others have covered my information above.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 02-25-2018, 06:02 PM   #18
Rewards Points: 1,305
Carpdad's pictures all depict hip framing on a rectangle. That's why there is a ridge.
The middle photo in post 16 is what your framing should look like. (From below)
XSleeper is offline   Reply With Quote
Old 02-25-2018, 06:05 PM   #19
jlhaslip's Avatar
Rewards Points: 708
Note that the image showing the detail of the Hip posted in @carpdad 's reply is an image of a Hip using Trusses and a Girder truss, so your stick framed Hip will look somewhat different in its structural form.
Old 02-25-2018, 08:39 PM   #20
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 528
Stop the build and I hope you didn't prepay much.
1. photo ridge is about 30% of the span. Your build is about 80% ridge. The side next to the roof will not be hip. That side, once roofed, will drain to the existing roof. It WILL start leaking there. Even if framed right, don't drain toward existing shingles. You need to move the build away from the house or think of something else.
2. One side doesn't have the hip rafter yet, but hip and the ridge are load bearing, unless there is a beam with all kinds of braces. Your ridge and rafters are all same size and not calculated to be load bearing. Search "hip roof framing".
CarpDAD is correct from what we can see........
In the pic above , I did not even notice it was being built onto your existing home untill Carp pointed it out.
If so, that ridge would have to continue until it intersects with your existing roof, and then overbuilt to your existing roof, creating two valleys for water runoff...... but I'm pretty sure that's not what your fellow is doing.
Give us a broad (over view) picture of what is happening......
Good luck
MTN REMODEL LLC is offline   Reply With Quote
Old 02-25-2018, 11:30 PM   #21
Rewards Points: 42
Good luck
Thanks for the replies. It will not be attached to the home and there will be a gap so water doesnít drain onto the home. But I was thinking the same thing about it not looking like it should... thanks for the replies.
omgdiddy is offline   Reply With Quote
Old 02-25-2018, 11:41 PM   #22
Rewards Points: 42
Originally Posted by BIG Johnson View Post
Originally Posted by XSleeper View Post
A hip roof on a square building has 4 hip rafters that all meet at the peak and nothing but jack rafters. It would only have a ridge if it is a rectangle, like the picture in post 5.
IMO, your "framer" doesn't have a clue of what he is doing and he's in over his head.
And those collar ties are a big fail.
Tell me how to fix them please? Also should I have the rafters notched (itís called a bird notch or something?) near the collar tie where they rest on the framing?
Old 02-26-2018, 07:42 AM   #23
Rewards Points: 898
Theyíre not? Itís hard to tell in the pics. and the notches wouldnít be very deep due to the low pitch, it still needs to be done.
BIG Johnson is offline   Reply With Quote
Roof Framing help - Cathedral Garage Roof with Trolley scootermcrad Building & Construction 6 08-15-2012 09:23 AM
Allowable roof loads for framing plummen Building & Construction 15 01-16-2012 07:05 PM
gable roof tie in framing moonshadow Roofing/Siding 4 08-20-2009 09:03 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Need help with framing roof for sunroom diehard_1955 Carpentry 1 04-27-2005 11:24 PM
