HELP With Worn Block Foundation Repair And Needed Follow-up - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2014, 01:02 PM   #1
HELP with worn block foundation repair and needed follow-up
When I first moved into my house I noticed (building inspector didn't in Feb.) the following summer that some of the block foundation is wearing out with some small cracks, mostly on the northern side due to a poor grade and drainage around the house. Having no money cause I just bought a house I pulled back the dirt, cleaned the block, removed loose material, and patched/repaired the worn exterior and cracks with Hydraulic Water-Stop Cement. It appears to be holding up very well in the areas that I can see. I also improved the grade and redirected the drainage.
Northwest Corner Outside
Northwest Corner Inside
Northern side
The problem is I then used BlackJack's Foundation paint and sealer to paint the above ground portions of my foundation along with about 1 block below grade. It states that you can use it above and below grade.
It is also important to note that there was a concrete slab that drained towards the home on the west side near the NW corner, which had worn a hole through the block. I have since removed the slab and patched the hole. The crack on the NW corner has reappeared, but very hair thin 2 years later.
As for the paint, I followed the directions perfectly. 2 years later the paint is peeling, not in flakes. looks like the northern side is too moist and it is shedding the paint sealer.
So what do I do now? Go back to digging and add an asphalt sealer to the entire side? remove as much paint as I can and redo it?
What about the crack that's reappeared? More photos to come.
Thanks,
Adam
VTOutDoorD is offline   Reply With Quote
Repair stucco on block wall. Advice? stupid48 Concrete, Stone & Masonry 6 02-03-2014 02:35 PM
Serious foundation issues, can't afford to repair, suggestions? Kellxr7 Concrete, Stone & Masonry 16 08-07-2013 06:37 AM
Rotted wood & Fieldstone foundation repair Glenmc Building & Construction 7 06-01-2012 08:49 AM
Crawlspace foundation repair bmrsnr Building & Construction 12 01-20-2011 10:21 AM
Jack & shim foundation repair steps - feedback appreciated! vacatari Building & Construction 14 10-17-2010 11:32 PM
