Help Needed - Vapour Barrier - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 09:26 AM   #1
Question
help needed - vapour barrier
I am desperately trying to find large rolls of BLACK vapour barrier, or any other similar type of film around 3 feet wide or larger. I need this for a haunted house we are setting up at my daughters school. Does anyone know where I can find this product in the Toronto or surrounding area?
motney is offline   Reply With Quote
Old 09-23-2010, 09:30 AM   #2
fabrk8r
fabrk8r's Avatar
Look for boxes of Visqueen plastic poly sheeting at your local home improvement store...comes in black and clear.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-23-2010, 09:34 AM   #3
I've been phoning hardware stores all morning, they always only seem to have the clear plastic but not black. I'm phoning everywhere I can think of right now...
Old 09-23-2010, 09:46 AM   #4
fabrk8r
fabrk8r's Avatar
Too bad you aren't here, I just pulled about 120 feet of 12' wide black poly sheeting off the shipment of steel that just came in...it'll end up in the trash...it's 4 mil thick.
Old 09-23-2010, 09:47 AM   #5
fabrk8r
fabrk8r's Avatar
Try landscaping suppliers.
The Following User Says Thank You to fabrk8r For This Useful Post:
motney (09-23-2010)
Old 09-23-2010, 03:49 PM   #6
Hi
Do a web search for 'breathable membranes' this should bring up a number of manufacturer's and/or suppliers if not suppliers then the manufacturers should have a list of stockists. Web sites should have a contacts page and if necessary you'll have to send them an email, hopefully you will have a stockist in your local area!
Another option is to check out local building or roofing suppliers in your area!
Good Luck
hereslookingatU is offline   Reply With Quote
Old 09-24-2010, 06:46 PM   #7
Rewards Points: 216
I found this via google at home depot canada
http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber
Good luck
orange is offline   Reply With Quote
vapour barrier on ceiling of bathroom? wilsonfrench Building & Construction 20 01-29-2012 08:08 PM
vapour barrier HELP!!!!! 06GT General DIY Discussions 8 02-23-2010 08:01 AM
Roxul without vapour barrier? giannit Building & Construction 8 01-26-2010 04:39 PM
Densshield and Vapour Barrier rayf01 Building & Construction 6 01-01-2010 12:55 PM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 08:56 AM
