Thread Tools | Display Modes |
#1 |
Rewards Points: 323
![]() Help me ID the exterior section of my house.
As soon as i open the backdoor there's an existing covered (on top) 5ft x 5ft concrete area with a single beam in the opposite corner that hold up the roof.
Does anyone know what this section is called? A bay, pad, patio, etc? I'd like to enclose two sides to make it into a small room. Please help? |
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 4,330
![]() Re: Help me ID the exterior section of my house.
Can you give us a picture or two?
Advertisement |
#3 |
Rewards Points: 323
Sorry this is a pretty bad picture. I got stuffs all over the place and its too cramp for me to take a good one.
Advertisement |
#4 |
Super Moderator
![]() Join Date: Mar 2005
Rewards Points: 29,516
A porch?
#5 |
Rewards Points: 323
Its made out of cement and not raised so i dont think its a porch?
#6 |
Rewards Points: 1,466
I can point out a few things that are incorrect about the existing situation.....but what you call it is not important (although slab or patio would likely work). Easy approach blow PT two byes Ono the concrete, use them as bottom plates, and then just frame up....and yes, you will get a dozen reasons why you shouldn't do that here....but that is different than whether or not you CAN. Ron
#7 |
Rewards Points: 323
Yup i plan on using 2x4 as bottom plate but i wont be attaching it to the cement via drilling. Instead the the vertical 2x4 on either side of the frame will be bolted or nail into the existing strucure of the house, provided if i can locatenthe studs.
About the pad, i guess it could be called a bbq area for the lack of a better word? |
#8 |
Rewards Points: 912
I certainly wouldn't call it a bbq area, it's way too close to the house. I would just call it a concrete stoop or pad. It's really nothing functional at all, just a slightly raised concrete pad that is designed to help prevent dirt from coming into the home.
Written using Dragon Naturally Speaking |
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Bleach Smell In House - Help! | broderbund | General DIY Discussions | 6 | 08-04-2016 08:01 PM |
My house's previous owner - DIY horror stories | Leah Frances | General DIY Discussions | 153 | 01-21-2016 08:18 PM |
Cape Cod Style House Attic/Crawl Space Insulation Help | Danielg | Insulation | 24 | 05-21-2012 09:20 AM |
Attaching wood fence to house | TheCowGod | Building & Construction | 5 | 04-13-2012 04:57 PM |
Attach ledger to vinyl sided house | JamyTheBuilder | Building & Construction | 3 | 03-14-2012 03:54 PM |
