Help With Framing For Insualtion - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-08-2015, 06:51 PM   #1
Rewards Points: 4
Help with framing for insualtion
Let me start by saying Im new to forum and Im not very experienced in carpentry. I recently decided i would insulate my 16x22 work shop. The rafters have me wondering what im going to do.. What i would like to do is add 2x6's on 24" centers about a foot about the top plate to increase my ceiling height and then insulate and hang osb. Is this going to be structurally sound with the weight of the osb. as of right now i only have a few rafter ties and and they sit on the plate. the garage is old but seems pretty square and sound.
I will add in hurricane ties to the rafters also. Please let me know what your thoughts are and if im heading in right direction. here are some pictures..dont mind the mess i have been moving everything off the walls to insulate.
benderbt is offline   Reply With Quote
Old 02-08-2015, 07:26 PM   #2
Rewards Points: 4,820
Maybe one of the moderators will be by soon concerning the pictures.?
ron45 is offline   Reply With Quote
Old 02-08-2015, 07:30 PM   #3
Rewards Points: 4
pictures
here are pictures
Help with framing for insualtion-img_20150208_145730_053.jpg   Help with framing for insualtion-img_20150208_145742_810.jpg   Help with framing for insualtion-img_20150208_145751_453.jpg   Help with framing for insualtion-img_20150208_145812_150.jpg
Old 02-09-2015, 08:02 AM   #4
Rewards Points: 272
You should search for lumber span chart. Look for lumber size that will span 16' deadload. Use them as rafter ties and a higher ceiling and insulate as an attic. Frame the eave side for r-30 insulation and vent space baffle and vent by adding vents that goes between the roofing. I don't think you have a soffit, so that is not a vent option here.
carpdad is offline   Reply With Quote
Efficient framing and framing lumber Geran Brown Building & Construction 13 11-17-2013 02:24 PM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 02:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 04:49 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
