Help Fill This Gap? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-23-2017, 03:05 PM   #1
Rewards Points: 369
Help fill this gap?
Any ideas on filling this gap at my back exterior French door?
About 3/4-1 inch.
Zamboknee is offline   Reply With Quote
Old 10-23-2017, 03:29 PM   #2
retired framer
Rewards Points: 6,198
Re: Help fill this gap?
What is the floor, is it floating, nailed or glued down?
Old 10-23-2017, 04:21 PM   #3
JUSTA MEMBER
Rewards Points: 1,604
I wish this site would orient the pictures correctly, I don't know which way is up.( no sarchasm please), so going from an earlier post, temporarily use one of those door draft ducks.
The kind that you lay at the bottom of the door, looks like a skinny tube filled with padding and a cute duck head for decoration.
ED
de-nagorg is online now   Reply With Quote
Old 10-23-2017, 04:26 PM   #4
retired framer
ED
It looks like the floor has been left with an expansion gap at the door.
The Following User Says Thank You to Nealtw For This Useful Post:
de-nagorg (10-23-2017)
Old 10-23-2017, 05:56 PM   #5
Rewards Points: 369
laminate flooring, floating.
Sorry for the odd angle pic. The top left is outside. tan stuff is the laminate flooring.
Old 10-23-2017, 07:52 PM   #6
retired framer
I think you might have to cut the floor back a little and then play with a transition strip that can be nailed or glued down and still allow for expansion.
http://www.laminate-flooring-install...ing-doors.html
toilet takes to long to fill lonewolf22 Plumbing 5 11-30-2011 08:03 AM
Toilet wont fill on its own fixitwoman Plumbing 2 10-18-2011 08:11 PM
toilet fill valve? Roundeye Plumbing 11 07-26-2011 02:17 PM
Slow toilet tank fill even with NEW fill valve? Zilla Plumbing 8 08-10-2009 10:37 PM
Would you spring to fill in your backyard? Piedmont Landscaping & Lawn Care 4 05-14-2009 09:14 PM
