Help With Chicken Coup Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 07:09 PM   #1
dIYHell
Rewards Points: 150
help with Chicken coup foundation
I am building a small 4X8 simple shed like building with no floor for chickens. I am trying to figure out the best and easiest way to make the foundation. I was thinking of using the fence posts on one side of my yard for two corners and put another two in for the others. Then just use some 4X4s raised 10" up for the base plates. Will this work, if so how would I tie the 4x4 baseplate into the corner posts?(Just toenail it to posts?).
below is a basic elevation view of the 4' what I am what I want to do
rocketdoctor is offline   Reply With Quote
Old 02-19-2010, 07:17 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Hey rocket doctor I always thought it was a Chicken Coop.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 02-19-2010, 11:08 PM   #3
dIYHell
Rewards Points: 150
You say soop I say soup, you say coop I say coup
Old 02-20-2010, 09:36 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,504
Ayuh,... Why not just build the shed with a doubled P/T sill plate....
Or, use the 4x4s for skids...
Then you could just drag it where ever you want...
No reason to tie it to the fence...
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 08:31 PM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 10:26 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 10:22 AM
Re-grading around foundation? robertr4836 Landscaping & Lawn Care 10 05-23-2009 05:34 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
