Help With Basement Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-03-2013, 01:28 PM   #1
Rewards Points: 14
Help with Basement Stairs
Hello, I am in the process of redoing my basement. This includes finishing the stairs and adding a wall on one side. currently my stairs just have treads and are cut past the stringers. my idea is to cut off the overhang of the current treads and add a plywood riser. I will then finish the stairs with a oak vaneer tread (simpletread) and riser. the wall will be going up on the right side of the stairs as you walk down, should i add a finish stringer to close in the stairs? any gotchas or ideas you can pass on to me will be a great help. thanks for your time!
Help with Basement Stairs-20131130_155338.jpg   Help with Basement Stairs-20131130_154836.jpg
audis$ is offline   Reply With Quote
Old 12-03-2013, 05:41 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 260
Check to see if there will be a difference in height in the rise of the first and last step if you were to add to the top of the tread. If so it would be best to remove the 2xs in shim or what ever it takes to insure each rise is the same. If someone were to fall on stairs where they were out of code, insurance will not pay. Also when selling your house they may make you correct them then. That call is up to you.
What I would do for the wall is build under the stringer with the 2X4s flush with the outside edge, that way you can install sheet rock on the wall and stringer with no trouble. Then you can member the risers in with the skirt board and continue on with your install.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-03-2013, 06:12 PM   #3
Rewards Points: 14
Thanks Jim! I will check the stairs but i believe they all measure out to be the same. As far as the wall. This will not be a half wall but one that goes all the way to the top extending past the stairs.. i can get a few more pictures to try and explain it better.
The Following User Says Thank You to audis$ For This Useful Post:
BigJim (12-03-2013)
Old 12-06-2013, 03:01 PM   #4
Rewards Points: 14
so i measured each individual stairs rise, and the rise from the first to the last stair is 7" that means that adding a new finished tread will throw the top and bottom stair off 3/4". is that within code? does it have to be exact? any ideas? I would like to do this right the first time.
thanks!
Alex
Old 12-06-2013, 03:59 PM   #5
kwikfishron's Avatar
Rewards Points: 64
You need to be within 3/8" to meet code. Take a look at picture #11 in this guide. http://www.precisionstairsystems.com...copy_1__1_.pdf
kwikfishron is offline   Reply With Quote
Old 12-06-2013, 04:46 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 260
In Tennessee it is 1/4 inch, I had to tear one out because it was 3/8 out several years back. Thanks for the stair code, some of those are different from Tennessee code, or the inspectors just wanted to be difficult.
Jim
Old 12-06-2013, 04:52 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 260
thanks!
Alex
Stock treads are usually 1-1 1/8 inch thick. To make the stairs all the same just subtract the thickness of the tread you put on from 1 1/2 inches and shim to that thickness using plenty of glue and construction adhesive.
Just another note, if you plan to run the wall all the way up to the ceiling be sure to add a 2X4 nailer flush to the bottom of the stringer as a spacer. You will be glad you did when you go to install sheet rock and the skirt board on that side.
Jim
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 07:02 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 09:55 AM
Outside basement stairs, bulkhead stairs, etc anesthes Building & Construction 0 03-29-2011 06:33 AM
Cutting drywall side of basement stairs? Oxymoron Drywall & Plaster 4 10-07-2010 10:13 PM
Basement Stairs/ EZ Stairs mjkpainting Carpentry 8 02-24-2010 10:24 PM
