Helical Piers & Shallow Bedrock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-14-2014, 06:44 PM   #1
Rewards Points: 252
Question
Helical piers & shallow bedrock
Are helical piers suited to foundation repair where the soil is over shallow bedrock?
A corner of our house has gradually settled over the last 10 years, causing stair step gaps/cracks in the brick/mortar outside, and cracks in the sheetrock inside. We have a quote from a reputable (BBB, Angie's List, etc.) foundation repair company to install three helical piers to lift and stabilize the concrete footing in that corner.
There is bedrock about 4 feet below the surface in that corner. So, most of the support for each pier will be provided by the bedrock, not the soil.
John_W is offline   Reply With Quote
Old 10-18-2014, 12:30 PM   #2
Rewards Points: 2,464
not the better choice to me & i'm a big fan of ramjack's guys - use a push pier instead
The Following 2 Users Say Thank You to stadry For This Useful Post:
gregzoll (10-19-2014), John_W (10-19-2014)
Old 10-19-2014, 11:33 AM   #3
Rewards Points: 1,042
Either one would work in your situation, but helical piers are usually used where the composition of the soil is known, with push piers it doesn't make any difference.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
John_W (10-19-2014)
how to veneer brick porch piers with stone pcshay Concrete, Stone & Masonry 12 06-23-2014 07:51 PM
Piers in crawl space dfiddler General DIY Discussions 2 07-30-2013 06:23 AM
Rebar in poured concrete piers montana_bound Concrete, Stone & Masonry 0 09-18-2012 11:10 PM
Building on piers & pressure treated posts, or just concrete piers? TinaRap Building & Construction 13 05-08-2010 03:00 PM
piers under a new addition shama144 Building & Construction 2 10-22-2008 12:19 PM
