Heavy Duty Bracket? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-26-2016, 07:37 PM   #1
Rewards Points: 50
Heavy duty bracket?
Hi,
Does anyone know where I can find a heavy-duty bracket (right-angle) like the one in the attached photo.
For scale, that's a 4x4 it's attached to.
(I'm not concerned about the metal spacer at the bottom of the post, keeping it off the concrete.)
Thanks!
philsmith22 is offline   Reply With Quote
Old 06-26-2016, 08:17 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Heavy duty bracket?
Looks like it might be a cut-off of Angle Iron.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 06-26-2016, 08:18 PM   #3
Rewards Points: 9,406
That looks like just steel angle (4 x 4 x 1/4) with some holes drilled in it. You can get some at any steel supplier or even Home Depot (used for lintels). If you only need one 4" long piece, try someplace like a Metals Supermarket, or similar. They might even drill the holes for you if you give them a sketch.
( If you buy the longer piece from Home Depot and cut it with a hacksaw, I guarantee you will wish you had found somebody to cut you off a 4" long piece on a bandsaw. )
SPS-1 is online now   Reply With Quote
Old 06-26-2016, 09:22 PM   #4
ZZZZZ's Avatar
Rewards Points: 1,244
Any local metal fabrication/welding shop can either sell you one off the shelf or make one for one fairly quick and cheap.
ZZZZZ is online now   Reply With Quote
Old 06-26-2016, 09:32 PM   #5
Rewards Points: 50
Ah, that's exactly what it is. Thanks!
Old 06-27-2016, 07:35 PM   #6
Rewards Points: 110
I needed a bracket like that and was able to purchase a "Z" bracket and cut it in two 90* halves. The angles were close enough to 90* to work.
I was reinforcing the inside of a 90 where two doubled 12" beams met as a corner.
Sent from my SAMSUNG-SM-N900A using Tapatalk
ChuckTin is online now   Reply With Quote
Ceiling fan install question with FB442 bracket jtjordan07 Electrical 5 07-04-2014 01:04 PM
Recessed light socket bracket AlamedaDIY Electrical 5 02-10-2014 03:50 PM
light fixture ground bracket gt1935 Electrical 2 08-04-2013 07:55 AM
Very old Basin Mounting Bracket Ultrarunner2017 Plumbing 3 06-26-2013 08:19 PM
Heavy Duty Casters BigJim General DIY Discussions 16 12-23-2011 05:48 PM
