Header Size In Structural Wall For Window Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2019, 09:59 AM   #1
Header size in structural wall for window addition
Looking to add two 34"x14" windows to my shop exterior wall. Studs are 2x4 on 24" centers. Is there a code I can look up, I assume mostly the size is related to snow load? I was thinking double 2"x10" headers would be sufficient? Do I need to jack stud on both sides as well?
Sent from my Pixel 2 using Tapatalk
colin83 is offline   Reply With Quote
Old 04-29-2019, 10:00 AM   #2
Re: Header size in structural wall for window addition
Oh and it's a single story shop.
Old 04-30-2019, 10:21 AM   #3
Rewards Points: 2,224
Not sure if this helps. https://www.familyhandyman.com/walls...-door-headers/
huesmann is offline   Reply With Quote
Old 04-30-2019, 10:29 AM   #4
retired framer
Rewards Points: 6,292
2 2x10s nailed with 3 3' nails in three place should be fine
Header will be 35" long
1 jack stud under each end one full length kind stud at each end
one 32" sill above and below the window.
The window will be a little smaller than the rough opening, about 1/2" normally.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
colin83 (04-30-2019)
Plumbing bathroom & laundry rooms zannej Plumbing 7 06-07-2018 05:53 AM
Questions on Construction of my House: Built in 1980's, questioning structural design ejumps Building & Construction 4 03-05-2016 06:55 PM
Is this wall structural - plans included Zif0684 Remodeling 10 03-25-2014 10:43 PM
Header size for ext. wall opening JulesB Carpentry 10 02-17-2011 08:52 PM
Removing part of a load bearing wall - what size header Mike Sch Building & Construction 1 01-09-2011 11:14 AM
