Header Hanger - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-21-2010, 07:14 AM   #1
header hanger
Hi, I have to replace a 34" front door with a 36" front door so I have to make RO bigger. I would like to use a header hanger so I can just take out the jack studs ,that would give me the space I need to do the job. The Q is are those hanger code in Mass? Can you find this in a code book or how do I find this? P.S. and thanks for all the help GREAT SITE
Boston Bean is offline   Reply With Quote
Old 09-21-2010, 01:35 PM   #2
Registered User
Rewards Points: 526
Ask your local Inspector. http://www.strongtie.com/products/connectors/HH.asp
Good for CA and FL.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
BigJim (09-21-2010)
Garage Header rwbil Building & Construction 11 09-16-2010 11:50 AM
Raise header of house wall plus add more header capslock Building & Construction 22 02-01-2010 09:13 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 03:20 PM
Garage Header Insight red3908v Building & Construction 4 04-27-2008 08:55 AM
Moving Header Supports Star Building & Construction 3 09-25-2005 12:50 AM
