Gutter Routing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 01:23 PM   #1
Gutter routing
Experiencing moisture problems under house...installed gutters, water running back to the house to the house now. What is proper way to run from the downspout?
Lelswick is offline   Reply With Quote
Old 07-24-2010, 01:42 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
ah...away from the house?
Tom Struble is offline   Reply With Quote
Old 07-24-2010, 04:27 PM   #3
Rewards Points: 5,348
It sounds like the grading of the house needs to be modified. The top soil should be higher at the house and then slope away. Water should exit the down spouts at least 3 feet away from the structure. More if you can.
Post some photos.
Ron
Squirrels chewing the gutter guards... gshock Roofing/Siding 3 06-29-2016 12:24 PM
Rain gets underneath gutter Heimwerker Roofing/Siding 8 12-28-2011 12:59 AM
Gutter leaks after roof replacement Jim F Roofing/Siding 6 04-16-2010 08:42 PM
Rain gutter slopes the wrong way ovahimba Roofing/Siding 2 12-20-2009 03:56 PM
"Frozen" Gutter Leak cougar01 Roofing/Siding 19 02-10-2009 06:07 AM
