Grounding Switches - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2009, 11:06 AM   #1
Grounding Switches
I was looking at a house for sale, and noticed that the light switches did not have the ground wire attached to the switch. I realize that power can go directly to the fixture, or through the switch, but shouldn't the ground wire be attached in either case? The house was built in 2000, but this particular county doesn't have building codes.
vf100 is offline   Reply With Quote
grounding switch? Jeremy Hillary Boob, PhD Electrical 15 08-02-2012 04:51 PM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 06:19 PM
grounding switches in old work plastic two gang box wkend2 Electrical 3 03-05-2008 12:33 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
Toggle switches: With or without grounding screw? Marekus Electrical 3 11-27-2006 03:48 PM
