Grinding Metal For Painting - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 09-04-2018, 04:02 PM   #16
Rewards Points: 22
Re: Grinding metal for painting
Not to scale, but here is how I welded plate butt joints. MIG or stick.
Gregsoldtruck79 is offline   Reply With Quote
Old 09-04-2018, 05:38 PM   #17
Endless Projects
Rewards Points: 1,418
I took it to my current welder. He might have been the previous welder also as I don't remember who welded it 20 years ago. He said at 1/4" even if butted up against each other the weld done right would penetrate 1/8" per side so full penetration and a good weld if I wanted to grind the weld off.
When this garage extension is done maybe it is time to take up welding, now that I will have the space.
SPS-1 and Gregsoldtruck79 like this.
Photobug is offline   Reply With Quote
Old 09-04-2018, 07:43 PM   #18
Rewards Points: 322
Well if you are going to learn to weld, learn to TIG and you wont need to grind it.
This is from the handrail inside my house. Welded on all sides with a small amount of filler rod. For something structural I would have added more filler but it would have looked just as nice.
Msradell and Gregsoldtruck79 like this.
rrmccabe is offline   Reply With Quote
Old 09-04-2018, 11:07 PM   #19
Endless Projects
Nice work rrmcabe,
I wish I could do that so I could build my own railing for my upcoming balcony.
Is TIG appropriate for stainless steel? My hobbies include sailing and brewing, both require using stainless steel so would like to learn how to work with it someday.
Old 09-05-2018, 07:16 AM   #20
Rewards Points: 322
Nice work rrmcabe,
Absolutely. my uncle built his own sailboat and I welded a lot of the stainless parts like the mounts for the railing and most the mast parts, anchor chain rollers, etc.
And almost all brewery and food stuff is TIGd. I used to be the plant engineer at a potato chip factory and that is where I learned how to do it.
Photobug and Gregsoldtruck79 like this.
Old 09-06-2018, 12:01 PM   #21
Rewards Points: 38
Following!this seems like a very interesting thread
barongan is offline   Reply With Quote
Metal porch attachment to metal building wheeler Building & Construction 2 04-16-2016 10:47 AM
Replacing latch on metal framed garden gate tinan General DIY Discussions 2 09-06-2015 03:26 PM
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 02:33 PM
Paint for Rust-Prone Exterior Metal Railings (Oil-Based Metal vs Epoxy vs Urethane) Einhorn Painting 9 06-19-2011 09:41 PM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 01:21 AM
