At Grade Deck - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-22-2010, 07:08 AM   #16
Rewards Points: 5,348
Originally Posted by fornews View Post
Can you give me your thoughts on another approach.
Use a single rim joist made up of 2 - 2x8s set on top of sonotube/footings spaced about 4'10" and 2x8x12' joists ? Use joist hangers in both the ledger and the rim joist. Joists 16" oc See a problem with that approach ? This would allow a 12'x24' deck with 1 beam/rim joist and 5 versus 8 sonotube/footings. Beam/Rim joist set on stand offs.
Jon
I see more bounce in the deck having 12' 2x8's. You could reduce the bounce with 12" oc joists, using blocking(2) in each joist bay. It won't be as stable as the original set up, though.
I always double up the perimeter rim joists on 3 sides of the deck.
Ron
Old 12-23-2010, 10:09 AM   #17
Originally Posted by Ron6519 View Post
I'd string 4 supports for up to 24 feet. That's one every 8ft. Over 24 ft, I'd go to 5 supports.
Ron
Would 8' span between the double row of supports still be OK using 2x6 joists, ledgers, etc. ?
fornews is offline   Reply With Quote
Old 12-23-2010, 10:10 AM   #18
Ron
Missed a key piece
Would 8' span between the double row of supports still be OK using 2x6 joists (16" oc), ledgers, etc. ?
Deck Staining Nightmare steven994 Painting 7 06-14-2017 04:56 AM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
