Gazebo Ceiling Trim - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-31-2019, 11:06 AM   #1
Rewards Points: 30
Gazebo Ceiling Trim
I am finishing the ceiling in the gazebo. Hip roof.
Trim question: Need to trim the corners and around the rafters. The corner pieces came together fairly well but around the rafters I have decent sized gaps to hide behind the trim. Not sure what wood I should use to trim it with. I found a pine trim to use around the bottom where the ceiling meets the header but it is only 1.5 inches. Too small to cover the joints in the corner and around the rafters. I held up a 1x4 - looks bulky around the rafters, but anything in the "trim section" of Lowes looks too wimpy. Wish the wood came in 1/2 x 2 1/2 size. Yeah, I know I could cut it but I'm not wanting to trim the thickness, I just want to buy it, get it up and be done.
Any suggestions?
Whatever I end up using I'm thinking I could stain it the dark color so it contrasts with the ceiling. Ceiling will be stained light/natural and the rest of the gazebo is cedar stained dark tobacco color.
Heres a picture. I circled the 2 areas.
Thanks!
diynonstop is offline   Reply With Quote
Old 03-31-2019, 12:54 PM   #2
retired framer
Rewards Points: 17,010
Re: Gazebo Ceiling Trim
Maybe a 1x2 over the crack and a cove or something on each side of it.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Tags
ceiling , gazebo , trim
Ceiling repair after Irma damages - plaster washer application? miamicuse Drywall & Plaster 53 01-25-2018 08:06 AM
Staple indents in plywood ceiling and trim. ctone Painting 8 05-11-2017 10:48 PM
Door & Window Trim / Casing Overhaul - Craftsman Style lohryx5 Remodeling 7 07-11-2013 07:52 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
