Gas Fireplace Insert - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 07:21 AM   #1
Hi there.
A friend has moved into an older home with a gas fireplace insert installed in the existing fireplace. They are finding alot of cold draft coming in from around the insert. Just wondering how safe it is to stuff pink insulation around the sides and top of unit to stop the draft?
Thank you
Brad765 is offline   Reply With Quote
Old 11-22-2010, 10:30 AM   #2
Rewards Points: 5,348
Originally Posted by Brad765 View Post
Hi there.
Thank you
Does your friend close the flue when the unit is not being used? Does the fireplace have a properly functioning flue?
I would check out these before making some make shift repair.
Ron
Old 11-22-2010, 10:43 PM   #3
Hi Ron6519
I am not totally sure, but when I looked into the small opening above the unit I could see what looked to be a small silver flex hose approx. 5" maybe 6" extending out the top, also the same joined at the cap on the roof extended out the existing chimney. Assuming that this hose is the chimney for the gas unit I can't see how the old flue could be closed if one still exists.
New Fireplace Insert w/ Stone Veneer cumak Building & Construction 4 07-15-2014 03:16 PM
Fireplace Insert Chimney Liner installation eric859 HVAC 11 03-04-2011 03:58 PM
electric fireplace insert too small - cover/flange recommendations? cdnsupguy HVAC 2 11-18-2010 05:58 PM
Removing a pre-fab fireplace insert MarkinTN1 Remodeling 1 10-09-2009 11:20 PM
Ventilation for fireplace insert dpreznik HVAC 3 07-28-2008 06:59 PM
