Garage Water Seep Through Floor? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-18-2010, 09:41 PM   #1
Rewards Points: 95
garage water seep through floor?
Hi,
Can moisture on the garage floor be caused by condensation, or is this water coming up through the floor?
The picture below was taken right after a rainshower....it is 80 degrees here in chicago. This home is 3 years old, and if I had to guess the builder probably skimped and did not put plastic before concrete was poured.
Thanks for all suggestions!
bergerdude is offline   Reply With Quote
Old 06-19-2010, 06:18 AM   #2
Registered User
Rewards Points: 526
If condensation, the whole floor would be wet, not just in the control joint from water below.
Be safe, Gary
Old 06-19-2010, 08:49 AM   #3
Concrete & Masonry
Rewards Points: 462
I'd say you're a great guesser. Very common to pour garages right over the gravel w/o vapor barrier. It is only required on heated garages here, & I assume it's the same there as well. The slab is merely "sweating" due to the high humidity & temperature differences between the earth & air.
I can't say I have any great long term solutions, as most sealers won't properly bond to a surface like this for any length of time. You may get lucky with a sealer called "siloxane", as it penetrates deeper, but it may not last real long either.
jomama45 is offline   Reply With Quote
Old 06-19-2010, 01:12 PM   #4
Rewards Points: 2,802
if it weren't so (*%#%*()&$# expensive, you could drill holes in the floor & sub-seal from underneath but that's usually only done for commercial/ industrial/institutional/municipal/state/fed stuff,,, rarely when someone has to spend their own $$$ but, rather, use up taxpayer's $$$
there are vapor barrier epoxies that would work but if there's head pressure, not likely !
Old 06-21-2010, 02:44 PM   #5
Rewards Points: 95
$5 worth of plastic could have solved this.
Anyway...would dryloc work on something like this?
The garage is on grade (I think)...meaning that the garage floor is not any lower than the surrounding ground.
Funny thing is, I get a good frost heave on my asphalt during winter....could my location just be THAT Wet?
Anyway, there are two gutter downspout that come off the garage, I will extend those in to the swale 8 ft. away, and possibly dig and put in draintile in the swale (if this would help???)
Thanks!
Old 07-03-2010, 01:22 PM   #6
Rewards Points: 95
Just an update....plastic/vapor barrier under a slab is Code in my area.
The concrete contractor says "they must have done it" if it is code, but thee is no way to check.
The Municipality whom gave the permit for occupancy to the builder says "our guys don't sign off on stuff they don't see" so it "must" be there.
A lot of covering their @sses to be sure.
What can I do dehumidifier, ceiling fan, exhaust fan?
Long term cost (electrical) and effectiveness opinions would help.
Of course everytime I open the garage door there will be a changeover with moist summer air.....
So any opinions? Thanks in advance!!
Water in Garage walds11 General DIY Discussions 7 02-14-2010 04:15 PM
Making a floor in a garage. What size floor joists? GD73 Building & Construction 2 07-19-2009 07:07 PM
Basement water meter below floor level redfox1 Plumbing 5 12-10-2008 09:20 PM
Blacktop on Garage Floor?? terrypearson Flooring 3 08-06-2007 08:05 AM
Raising Garage Floor to match House Floor felice_oggi Building & Construction 2 09-22-2006 08:26 PM
