Garage Shelf - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2010, 04:09 PM   #1
Rewards Points: 110
Garage Shelf
Hello Everyone
New to the forum and love doing DIY, so i guess i am in the right spot.
Quick questions, i am installing a shelf that runs from wall to wall in my 1 car garage. I am using 2x6 timbers for a ledger board and the cross beams with a 3/8 plywood as the surface.
One wall is concrete. I am confused and looking for clarification here. Should i use tapcon screws? or masonary anchors to fasten the ledger board to the concrete?
Amitabh9 is offline   Reply With Quote
Old 10-21-2010, 05:28 PM   #2
Rewards Points: 5,348
I would go more heavy duty then the tapcons. Once it's up, it gets loaded.
How far are you spanning with the 2x6's?
Ron
Old 10-21-2010, 05:36 PM   #3
Rewards Points: 110
Ron
12ft.
Old 10-21-2010, 05:52 PM   #4
Originally Posted by Amitabh9 View Post
12ft.
That's along way for a 2x6 without a median support.
How deep will the shelf be?
Ron
Old 10-21-2010, 07:35 PM   #5
Rewards Points: 110
Ron
Sorry, i meant 8ft. not 12. the shelf will be 6 ft deep.
Old 10-21-2010, 07:50 PM   #6
Four or five 2x6's bolted to the studs and the concrete should be fine.
Ron
Old 10-21-2010, 08:12 PM   #7
Rewards Points: 110
Cool thanx.
I will not be using tapcons, just to confirm
Amitabh
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
want to build corner shelf for 27" tv in garage bowanna03 General DIY Discussions 2 07-08-2009 06:09 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Hanging shelf (mini "loft") from finished garage ceiling bdr Carpentry 6 11-30-2008 10:31 PM
Storage shelf above garage door BigMonkey Building & Construction 5 08-25-2008 12:05 PM
