Garage Roof Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Nealtw
Old 10-17-2017, 11:49 AM   #1
John McLean
Rewards Points: 26
Garage Roof Framing
For a garage 24 wide by 26 long with a 4/12 pitched roof what should the size for a cut roof be of the ridge board and joists and their spacing?
Johnrmclean is offline   Reply With Quote
Old 10-17-2017, 01:06 PM   #2
retired framer
Rewards Points: 1,688
Re: Garage Roof Framing
Get engineered trusses.
With rafters and ceiling joists you will need a beam or wall down the center.
jlhaslip likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
mga56grg (10-17-2017)
Old 10-17-2017, 03:53 PM   #3
John McLean
Rewards Points: 26
Why can't I do a cut roof??
Old 10-17-2017, 04:59 PM   #4
Rewards Points: 1,066
You can, it'll just be easier with trusses.
We also can't really tell you what the specs are going to be for your building. Local codes, snow loads, design, etc. mean too many variables for us to just spit out a number for you.
NotyeruncleBob is offline   Reply With Quote
Old 10-17-2017, 05:58 PM   #5
retired framer
You need someone that understands all the engineering required. So you add the cost of that person to the material and the value you put on your time.
And then compare that to trusses. 2 people one day, maybe two for the learning curve. For a few more bucks you could get the bonus room too but that would really increase the pitch.
Old 10-18-2017, 07:56 AM   #6
Rewards Points: 264
NJ and snow load 30. House about those numbers, either way. I used 2x6 for the rafters but the inspector had recommended 2x8. 2x10 ridge board, ceiling joists as collar ties and midway rafter ties. By the book rafter ties is one third of the height toward the ridge. Plan was diagonal brace to the rafters and the mid house beam, but inspector did not like the added load, probably because bsmt mid beam was engineered without the braces in the plan. Where I didn't put the rafter tie, roof dipped a little. Rafter ties every rafter, 16" oc. Passed frame inspection. Search for rafter span charts and your area snow load. Also see if the span chart says anything about the types of roofing and how many layers. Neither an engineer nor the most experienced framer, so I over-engineer to compensate. Also, depends on the inspector. Some would want every stick by the book.
Truss would give you a clear span, but regular framing would cost less. If using i joists, 4:12 roof may not work because you can cut only so much from the i joist where it intersects with the rafter on the wall plate.
carpdad is offline   Reply With Quote
Old 10-18-2017, 03:58 PM   #7
Rewards Points: 4,804
Just little bit of.
ron45 is offline   Reply With Quote
Hip roof garage ianmacneil Building & Construction 7 07-02-2014 12:18 PM
Roof Framing help - Cathedral Garage Roof with Trolley scootermcrad Building & Construction 6 08-15-2012 09:23 AM
Seal Leaky Garage Roof from Within? Boiler98 Roofing/Siding 4 03-11-2012 05:22 PM
Roof Under Garage Deck doublejz Roofing/Siding 4 04-18-2010 08:09 AM
Deck on Garage roof billybarty Building & Construction 2 02-26-2008 05:33 PM
