Garage Rafter Supports - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree2Likes
Old 09-10-2019, 11:50 AM   #16
Hammered Thumb
Rewards Points: 2,066
Re: Garage Rafter Supports
Originally Posted by huesmann View Post
Actually, the king post would be in compression.
(You're also assuming each member is zero dimension.)
Are you assuming the members are weightless, and that the only load on the roof is due to the roof covering?
Everything has weight, its called gravity. In structures, there are internal forces (how the load is transferred) that you cannot see with your eyes. Rather than getting in a back and forth on this thread, you can search the web for a little basic information. I did a quick one for you, here it is.
3onthetree is offline   Reply With Quote
Old 09-10-2019, 11:59 AM   #17
retired framer
Rewards Points: 20,634
Originally Posted by 3onthetree View Post
Everything has weight, its called gravity. In structures, there are internal forces (how the load is transferred) that you cannot see with your eyes. Rather than getting in a back and forth on this thread, you can search the web for a little basic information. I did a quick one for you, here it is.truss
You have to agree that compression down the center to 20 ft 2x4 would have done nothing to hold the roof up. I think the question is, does the roof have a sag in the middle that should be corrected. If not, no loss.
Do not use flat bottom gables with scissor trusses.
Old 09-10-2019, 12:15 PM   #18
Hammered Thumb
That's the thing, a king post does not hold the roof up, that's why you usually find only a couple and minimal size at that. Gable rafters don't need them - they push out the outer walls, which in turn "stretches" the ceiling rafters, which "bends" the ceiling rafters down. So a king post "pulls" up on them.
If the rafters, king posts, braces, and ceiling ties were all transferring the "weight" directly down, this roof would have collapsed immediately.
Old 09-10-2019, 12:28 PM   #19
retired framer
when we do trusses for heavy snow loads the big concern is the 2x4 or 2x3 members bending side ways under load so we get a list of crap to add to trusses to keep those members straight. So 1xs were there just to hold the joists up and i think they can be removed. The new 2x10s will sag but they don't need that support or something could be added to the side like in a nee wall position.
Old 09-11-2019, 07:01 AM   #20
Rewards Points: 2,761
If everything has weight, then all non-vertical members will be in both tension and compression.
I see you are assuming the joists are not continuous, and instead have a joint in the middle, at your kingpost.
huesmann is online now   Reply With Quote
Old 09-14-2019, 04:59 AM   #21
retired framer
A compression member is between other members. A tension members is nailed on the side of other members
