DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Building & Construction (https://www.diychatroom.com/f19/)
-   -   Garage pull up bar (https://www.diychatroom.com/f19/garage-pull-up-bar-135484/)
starkhd 02-29-2012 05:06 PM
Garage pull up bar
2 Attachment(s)
Have 23' 2x9 d-fir ceiling joists in my garage. The joists are braced with plywood that runs the length of the garage.
I recently installed the pull up bar (pic below) using 3/8" bolts with cut washers and nuts.
I weigh approximately 208lbs. I was thinking that I might add an additional 2x6 brace from the joist to the truss above on the right side of the pull up bar.
Any thoughts / suggestions on how to do so would be appreciated.
Attachment 46743
Gary in WA 02-29-2012 09:34 PM
I would attach a 2x on top the joists, run perpendicular to the joist/rafter, then attach the bar to that. You would be distributing any weight on two different joists and not have the tipping load as there is now.
Gary
bob22 03-01-2012 05:42 AM
Why not bridging between the rafters to reduce tipping instead of moving the bar?
woodworkbykirk 03-01-2012 08:06 PM
bridging between the bottom chord of the truss wont be as strong as gbr's idea. by going with 2x on top of the bottom chord you accomplish the same thing as the plywood but have more meat to fasten the chinup bar too.. the bolts or screws are more likely to pull out of the plywood than 2x
Yoyizit 03-02-2012 07:36 PM
How much joist deflection do you get when you yank yourself up? How 'bout when you're just hanging there?
starkhd 03-02-2012 08:49 PM
The deflection when i pull up is noticeable, but doesnt seem severe.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
