Garage Floor Leveling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 08:33 AM   #1
Question
Garage floor leveling
Hello,
I have a car and a half garage, that is connected by a wall to my small living room, I would like to add some space to my living room,about 6 feet worth, the problem is the floor is about 1 foot or more lower in difference, what can I do to have it raised up to the level of the living room floor? What materials are needed? and about how much is the cost and can it be done? What kind of contractor do I call? Right now the living room has wood flooring that I am going to add to when the project is finished. any suggestions are greatly appreciated.
mlo430 is offline   Reply With Quote
Old 02-25-2010, 04:27 AM   #2
Rewards Points: 3,614
any competent carpenter should be able to construct this floor for you,,, if i did it, its not difficult 6mil vapor barrier, p/t 2x ? floor joists, 3/4" t & g marine plywood, sub-floor, final surface covering
btw, insulation 'tween the joists would benefit your tootsies GREATLY
Old 02-25-2010, 10:55 AM   #3
Rewards Points: 5,348
To get a cost, you would just call in local contractors and get estimates.
Ron
Old 02-25-2010, 02:26 PM   #4
Thank you for answering my question so fast, Thanks for the advice, greatly appreciated,any suggestions on how I can convince my husband to do the project?
Old 02-25-2010, 04:20 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
One thing I would like to add. If and when you decided to job it out or perform this your self. When ever I'm matching anything per existing I would suggest using engineered lumber for the floor joists. The wall your going to remove is resting on a foundation. the new floor system is going to shrink. especially p.t. floor joist's in two to three years there will be a noticeable hump if you don't use the joists I suggested.
You will also have to see which way your flooring is run. I'm thinking the floor joists run parallel to the wall you want to remove. that said, there is allot of saw too thing that will need to be done once the wall is removed.
not to mention the flush header that needs to be designed and installed.
Is this something your husband could take on???. Bob.
Old 02-25-2010, 04:26 PM   #6
You need to realize there needs to be a firewall between the garage and the extension into this space. Your husband needs to isolate the living space from the garage.
Ron
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 07:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
