Garage Extension Roof Pitch Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-15-2016, 09:48 PM   #1
Rewards Points: 30
Garage extension roof pitch question
I have a 24'x24' garage with 6/12 pitch that I am attaching on back end a 16'wx8'd shed/extension, Just wanting to make sure my calculations are correct, my run is actually 7' 11.5" and rise at 6/12 would be 47 3/4" giving me a 26.6 deg angle that I will need to cut each end of rafter to attach to ridge board, my rafter will be right @ 8' 10 3/4" not including my 12" over hang and 3/4" subtraction for ridge board thickness so that would make overall rafter length being 9'10". (Is 12" overhang suffice/standard). Walls are right at 7.5' height
Does all this sound correct so far? And how would I make sure to cut the birds mouth correctly?? And with using 2x6 rafters @ 24" centers I need a 2x8 ridge board correct?.
Ceiling will be open with no joists. I live in Louisville KY and winters are mild for most part snow load is 15 psf. I will be using rafter ties.
Oh and what about wall and roof sheathing I was thinking 7/16 x 9' OSB for wall horizontally because each wall is just an inch or two over 8' like 97" and I didn't want to gap anything or make a 1-2" strip and OSB is only thing that comes longer then 8' and for roof was thinking either 1/2" or 5/8" plywood.
Any thoughts oversight, errors, or corrections I need to make. Thanks
mustangsally is offline   Reply With Quote
Old 09-15-2016, 11:18 PM   #2
Rewards Points: 1,466
Re: Garage extension roof pitch question
Obviously I am not a roof guy or I would have understood what you said. Google "how to use a framing square to cut rafters" and you will get all of your answers. Ron
ront02769 is offline   Reply With Quote
Tying in New Garage roof to old garage roof brew92 Roofing/Siding 14 06-10-2017 08:09 AM
Hip roof garage ianmacneil Building & Construction 7 07-02-2014 12:18 PM
Sagging roof question han0522 Roofing/Siding 8 12-20-2012 04:00 PM
Building Roof over Roof, changing pitch Thomas O Roofing/Siding 7 03-05-2008 10:51 PM
