Garage Built Into Hillside - Buried On Two Sides - Leaning Badly - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-03-2018, 10:39 AM   #1
Rewards Points: 168
Garage built into hillside - buried on two sides - leaning badly
Hi all,
I recently purchased a home with a garage built into a hillside.
It is leaning badly. I am almost certain this is because of insufficient draining and improper grading.
Basically, the earth has been allowed to slope towards the garage on two sides. I can see where the water is getting up against the walls. It seems to be eroding the topsoil in a couple places, and with no proper drainage, it likely causing bad pressure and the lean.
Someday I might want to replace the garage - but for now I just want to stabilize it from falling further into the neighbours'.
My tentative plan is to dig out the topsoil around the poorly graded sides, and replace it with impervious fill that is properly graded away from the garage. Then do a thin layer of topsoil above that for grass.
I know that, in addition to the impervious soil, it should have drainage - but the proper place for that would be at the bottom of the foundation - and that would be a massive job, needing an excavator (as you can see, it is basically impossible to get any kind of excavation equipment up to this area).
I am also considering the use of foundation wall anchors like this (https://www.supportworks.com/solutions/geolock.html), which would also, I hope, stop the garage from leaning further.
What do you think? Would grading with impervious soil keep this thing from leaning further? Or do I need to consider more drastic measures (wall anchors, or worse, completely digging out the soil around the garage...which is probably about 6ft deep).
Pics below.
Garage built into hillside - buried on two sides - leaning badly-pf64mzn.jpg   Garage built into hillside - buried on two sides - leaning badly-pkxq6rk.jpg   Garage built into hillside - buried on two sides - leaning badly-svy2fms.jpg   Garage built into hillside - buried on two sides - leaning badly-thq3zgy.jpg   Garage built into hillside - buried on two sides - leaning badly-uodysim.jpg
jmetrail is offline   Reply With Quote
Old 07-03-2018, 01:15 PM   #2
retired framer
Rewards Points: 5,774
Re: Garage built into hillside - buried on two sides - leaning badly
The newer concrete retaining wall has been added and back filled. The garage was not built to be a retaining wall.
At the very least you need drainage, I think you need an engineer
Old 07-03-2018, 10:29 PM   #3
Msradell's Avatar
Rewards Points: 974
It looks like a large part of your problem is caused by your neighbors retaining wall and enclosed area. I'm guessing that enclosed area with a fence around it is a swimming pool? If that's the case it's exerting an extreme amount of pressure against the sides of your garage, something the garage probably wasn't designed for what it was originally built. In most areas that structure would not have been allowed to be built unless a complete engineering study was done to determine that it would cause structural and runoff issues and neighboring properties.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Is there a way to ACCURATELY gauge size of buried cable to detached garage? BT5150 Electrical 18 12-30-2014 02:31 AM
Garage door water barrier eharri3 Building & Construction 3 01-14-2014 09:01 AM
newby having garage built - reasonable cost of framing? zman1969 Building & Construction 11 10-05-2012 01:12 AM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Has anyone built a shed as an extension to their garage? CoconutPete Building & Construction 5 03-31-2010 09:54 PM
