Gap Between Brick And Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-17-2010, 06:43 AM   #1
Rewards Points: 150
Gap between brick and ceiling
looking for a way to fill the 3" gap between brick wall and plywood ceiling above. it is indoors (it is an addition to the house if you are wondering).
i'd like to seal the gap to eliminate egression point for insects and air exchange with the attic. I've thought of putting a piece of plywood then sealing it w/ tape and mud. but i think the mud might be sloppy on the brick.
after sealing it, i'll put a crown moulding to cover this.
rosco is offline   Reply With Quote
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 08:11 PM
Run wire to Breezeway through brick and up brick wall wad2k Electrical 0 04-16-2010 08:18 AM
An extensive 'drop ceiling' project- where to begin... kpatten Remodeling 7 02-05-2010 06:31 PM
How to fill a gap between basement ceiling and brick wall simonw Building & Construction 5 01-12-2009 01:00 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
