Furnace Size - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 12:08 PM   #1
Furnace size
is a 120,000 BTU furnace too big for a 2000 sq ft home
Jeffrey Hewitt is offline   Reply With Quote
Old 12-09-2010, 12:13 PM   #2
Rewards Points: 5,348
It might be helpful if you said where you lived and whether the btu rating was input or output.
I have a 2500 sq ft house on LI, NY with a hot water boiler with an input of 145,000. Works fine.
Ron
Old 12-09-2010, 02:00 PM   #3
Rewards Points: 238
I suggest you head to http://www.diychatroom.com/f17/
where HVAC people can likely better advise. Sounds a bit high to me but you need to have a manual J done to best determine your heating/cooling needs.
bob22 is offline   Reply With Quote
Old 12-09-2010, 03:04 PM   #4
If you can't get someone else to do the manual J calculations for you, you can do them yourself with this software: http://www.hvaccomputer.com/
mackintire is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
How to Size a Furnace super_man4471 HVAC 18 03-25-2010 09:12 AM
Furnace size krb HVAC 8 11-14-2009 01:40 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 11:55 AM
