Full View Storm Door Southern Exposure Advice Wanted - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 06:21 AM   #1
Rewards Points: 38
Full view Storm Door Southern Exposure Advice Wanted
I have varnished wood entry door that faces south. It needs a replacement storm door. While researching storm doors on the web, I read that a full view storm door is not recommended for a southern exposure. Is that statement true or false?
I live in the Midwest, if that affects the answer.
kc27 is offline   Reply With Quote
Old 10-27-2010, 07:24 AM   #2
Professtional Remodeler
The reason that they do not recommend installing storm doors on the south side is because of the sun. You are asking for trouble if you have no covering such as a small porch roof to protect the door. When you install a storm door that gets direct sunlight, the temperature between the entry door and storm door can reach temps exceeding 300 degrees. With a wood door, the finish will deteriorate and the door will dry out quickly. Hope this helps.
valueremodeling is offline   Reply With Quote
The Following User Says Thank You to valueremodeling For This Useful Post:
Tom Struble (10-27-2010)
Storm Door Selection/Brand Advice Wanted kc27 General DIY Discussions 3 10-25-2009 08:17 AM
Kinetico Water Softeners -Reverse Osmosis Questions...Help - Advice wanted.. OverRunWithSons Plumbing 7 07-26-2009 12:14 AM
Basement Finishing Advice Wanted PJU1971 Carpentry 4 04-04-2009 04:04 PM
