Framing A Wall In My Metal Building - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-17-2014, 10:06 AM   #1
Framing a wall in my metal building
Fair warning: First time framing a wall.
I have a 50'x30' metal building, with a slab floor and wooden posts, that I want to divide in to two large rooms. The building has 6 large ceiling trusses that are 30' wide. One truss on each end and the other four spaced 10' apart down the length of the building. I plan to frame a wall underneath one of the trusses that divides the building into one 30'x30' room and one 20'x30' room. Below is my framing diagram and materials list.
I plan to fix the bottom plate to the floor with the Ramset nails and nail the end studs to the wooden posts on either end of the building. I have do not currently plan to nail the top plate to the truss above it because I'm not sure what affect that would have on the roof structure.
I would really appreciate any feedback or guidance!!
Purchase List
$118.36 (22) 2x4x12'
$39.06 (9) 2x4x10'
$15.81 (3) 2x4x10' Pressure Treated
$16.14 (2) 2x10x8'
$6.96 (1) Ramset 100 Yellow Shots
$15.97 (1) Ramset 100 3in. Pins w/ Washer
$25.98 (1) Ramset Hammer Shot
$10.00 Nails
Total: $265.66
wigginjs is offline   Reply With Quote
Old 09-19-2014, 07:11 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
it looks like you have it all figured out. if the truss is wood you can nail to it most likely, in fact you need to nail the top to something. have you considered using metal framing instead of wood because it is a metal building?
hand drive is offline   Reply With Quote
Old 09-19-2014, 07:55 AM   #3
Rewards Points: 144
You will need to attach the top plate to the truss.
mako1 is offline   Reply With Quote
Metal Edging and Odd Connection Point on Wall cloves Tiling, ceramics, marble 4 06-21-2014 05:34 PM
Re: old buildings RWolff Building & Construction 157 01-19-2014 01:35 AM
Basement wall framing Lemkie Building & Construction 6 03-08-2013 10:01 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
