Framing Wall, Help! - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 02-27-2018, 05:26 AM   #16
retired painter
Rewards Points: 560
Re: Framing wall, Help!
first you said
The length/width of the room I am building is 8' x 10'
then
One wall will be 98' long the other will be 128' long.
Be sure you get your measurements correct before you start! 8' = 96" 10' = 120"
mark sr is online now   Reply With Quote
Question regarding likely framing behind fireplace on exterior wall JKeefe Building & Construction 11 01-07-2014 01:39 PM
Basement Wall Framing trophywalleye Remodeling 9 01-13-2012 12:15 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Non-Load Bearing Wall Window Framing? ericht Building & Construction 28 01-27-2010 08:38 PM
Framing stair knee wall... bparise Carpentry 6 11-14-2009 12:03 AM
