Framing Under Beam - Isolating For Sound - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By spaz
Old 03-15-2019, 01:05 PM   #1
Rewards Points: 44
Framing Under Beam - isolating for sound
So I'm framing a wall under a steel beam that runs the length of my basement. I'm trying to build a music room so I'm going to be doing isolation channels and two layers of drywall.
My question though is should I be worried about screwing the top plate directly under the beam? Should I use some kind of material between the two so the wall doesn't vibrate the beam? Know what I'm trying to say?
And I plan on cutting small 2x6's and gluing them onto the beam so I can add the channel at the top of the wall. Will that be a problem?
spaz is offline   Reply With Quote
Old 03-15-2019, 01:10 PM   #2
Rewards Points: 44
Re: Framing Under Beam - isolating for sound
Old 03-15-2019, 01:24 PM   #3
retired framer
Rewards Points: 15,108
The beam should be drilled so you can add a plate to the bottom or fill the inside with lumber, With out that I would build the wall on one side or the other and then box out the beam
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Nealtw is offline   Reply With Quote
Old 03-15-2019, 02:25 PM   #4
Rewards Points: 44
I got that part, my question is, is there anything I should put between the frame and my top plate so the framing doesn't send extra vibration into the beam? Like the green glue joist tape or something
Old 03-15-2019, 02:30 PM   #5
retired framer
I haven't seen it used but this is what they advertise it for. I think it would be worth trying.
figure 7-14
Old 03-16-2019, 09:09 AM   #6
Rewards Points: 4,320
What you want is sill seal, like this: https://www.amazon.com/Dow-Sill-Seal.../dp/B074KK3XGD
I'd drill a few small (3/8" or less) holes in the bottom flange and bolt (or screw if you can fit a suitable driver between flanges) your header frame member to the bottom flange with a layer of sill seal between them. Then frame out as necessary below that.
However, depending if/where you plan on walling parallel to the joists, what's your plan for dealing with the column? If you plan to have your wall continue past the column, what Neal suggests is a better idea—just screw your top plate to the joists in front of, or behind the beam. If you do it in front of the beam, you don't need to worry about boxing out the beam, unless you also finish out the area behind the wall.
Also, what's your plan for the area above the beam, where the joists go across it? Are you planning to drywall in a ceiling too?
Consider using some MLV in your wall (and ceiling) too.
huesmann is offline   Reply With Quote
Old 03-16-2019, 08:38 PM   #7
Rewards Points: 44
My plan is to use construction adhesive and glue in sections of 2x6 into the beam so I can run the channeling for the drywall.
Old 03-17-2019, 09:07 AM   #8
Beam looks painted...don't know how well construction adhesive will stick. I still think you're gonna have to end up drilling holes, but the beam web is actually a better place for them.
Old 03-18-2019, 03:55 PM   #9
Rewards Points: 44
Started framing the last long wall under the beam
This was a lot of work.. but drilled all the top plates into the beam
Nealtw likes this.
Old 03-18-2019, 06:14 PM   #10
retired framer
That looks good, but did you put something between wood and concrete?
figure 7-14
Old 03-19-2019, 07:46 AM   #11
Ah, so you did use the flange after all.
Old 03-19-2019, 11:19 AM   #12
Rewards Points: 44
hmmm.... crap no.
I was only thinking about how much that steal beam vibrates and hum when you hit it. The concrete not so much. But I get what you're saying now and now wish I would have.
Old 03-19-2019, 11:20 AM   #13
Rewards Points: 44
yeah ended up finding a roll at HomeDepot
Was super cheap and figured anything is better than nothing!
Old 03-19-2019, 11:23 AM   #14
retired framer
hmmm.... crap no.
I have seen lots that are years old with no effect but the rules is never let wood touch concrete, even treated wood as the moisture that can wick up thru concrete will sit in the wood and lead to rot.
figure 7-14
Old 03-19-2019, 11:25 AM   #15
retired framer
That cheap stuff you used is sill gasket, made for going between wood and concrete. oops.
figure 7-14
Tags
beam , framing , isolation
beam replacement and sistering Bamboozler Building & Construction 22 06-20-2016 12:01 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Framing Ideas (supporting 2x6" beam) colinp123 Building & Construction 7 05-17-2012 09:53 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
stick framing a shop sagging troubles on the main beam please help!!! weekendwork Roofing/Siding 8 09-24-2005 01:02 AM
