Framing Stucco Details - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2009, 12:31 AM   #1
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
Framing stucco details
Anyone have any insight on how to frame some columns to be covered with stucco? I've attached a pictyre to explain.. I was thinking 2x10 for the bottom of the column and then some plywood for the tall part going to the top of the column.. or maybe double 2x10 for the bottom/top and 1 2x10 for the tall part? to add some mroe width
ryanh is offline   Reply With Quote
Old 07-17-2009, 08:10 AM   #2
I think the stucco guy can work with anything you give him. Have you looked into styrofoam buildouts? I think that they only work with acrylic stucco though.
the carpenter is offline   Reply With Quote
Chimney Stucco Repair mikeyboy Building & Construction 7 04-11-2009 11:33 AM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 03:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 07:07 PM
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 12:48 PM
