Thread Tools | Display Modes |
#31 | |
Rewards Points: 66
![]() Re: Framing QuestionQuote:
Kenny |
Sponsored Links | |||
Advertisement |
#32 | |
retired framer
Rewards Points: 1,494
kenny4 likes this.
The Following User Says Thank You to Nealtw For This Useful Post: |
kenny4 (09-07-2018)
Advertisement |
#33 |
Rewards Points: 66
So you would have 2- 2x6 top plates and a 2x6 block directly under them? Most of the framing around here aren't using mid-stud fire blocks,open from green to top plate.-----This adds another question. Does the drywall on the 1st floor ceilings have to be fire rated? Thanks
Kenny |
Advertisement |
#34 | |
retired framer
Yes ceiling drywall applies to all ceilings, kenny4 likes this.
#35 |
Rewards Points: 66
On the exterior then you would use 8' shear top and bottom and a 2' band in the middle.
Kenny |
#36 | |
General contractor/carpen
![]() Framing QuestionQuote:
I don't see why you shouldn't use 2 - 9' sheets on the outside with blocking, if your total height is 18'. Makes perfect sense. ____________________________________ ![]() ![]() kenny4 likes this.
#37 |
You could save the work of blocking and put the break at the wall plates. There's no code here that says shear needs to go 12" past your plates. As long as you follow your nailing schedule it shouldn't matter.
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Shed Roof Fascia and Framing Question | crhage | Building & Construction | 3 | 06-22-2011 07:54 AM |
Above grade framing and a few framing question | jreed | Building & Construction | 6 | 01-16-2010 11:56 AM |
Framing Question | flati | Building & Construction | 10 | 01-12-2010 11:24 AM |
Balloon Framing Question | zetti1102 | Building & Construction | 2 | 09-30-2009 10:50 PM |
stupid framing question | amakarevic | Building & Construction | 12 | 02-23-2008 04:29 PM |
