Framing Out Sunken Floor To Match Existing Subfloor - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree6Likes
Old 10-24-2017, 06:53 PM   #16
Naildriver
chandler48's Avatar
Rewards Points: 1,292
Re: Framing out sunken floor to match existing subfloor
Most decks are not level . they have a slope so water drains off
Never understood this theory. If a deck has holes between each board, why would it need to be sloped? Water will run off the sides of the boards into the cracks.
Ktmrider, why go through all that trouble when you can do it right.....once?? Your method still leaves you short.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 10-24-2017, 08:13 PM   #17
Rewards Points: 2
only a 1/4", but did you notice that I said I wouldn't do it that way, but he was looking for different ways so I told him that
ktmrider is offline   Reply With Quote
Old 10-24-2017, 08:26 PM   #18
retired framer
Rewards Points: 6,106
We don't know the type of deck. half of our decks are solid surface with a slope..
Old 10-24-2017, 08:46 PM   #19
Naildriver
chandler48's Avatar
Ouch !!
Nealtw likes this.
Larry......
Old 10-24-2017, 08:52 PM   #20
retired framer
Ouch !!
We build on hills so most of the time it will be a deck above a slab patio below or deck over garage. they are all treated like a roof with 1/4"per ft slope. It is probably more than half.
Old 10-25-2017, 06:17 AM   #21
Naildriver
chandler48's Avatar
I've done one deck like that, but the owner stipulated that I put down Advantech for decking. He, then, proceeded to layer it with a fiberglas mesh and some white liquid, for about 4 layers. The last layer had granules for a walk surface. It worked fine and had the slope as you stated, but only because it was solid. It was an oddity for this area.
Larry......
Old 10-25-2017, 09:24 AM   #22
retired framer
Years ago we did fiberglass just like a boat. But now we have a sheet vinyl that is made for that. Or peel and stuck under concrete. Any of them have to run up wall the six or eight inches and under the doors.
There are paint on products but never seen them done since the 60s. They were crap then.
Installing Floating Bamboo Over Existing Wood Subfloor TapEx Flooring 1 03-12-2012 11:11 AM
plywood over existing subfloor - not glued? rtoni Flooring 3 10-14-2010 12:37 PM
Adding a room, tie in to existing framing rampeyboy Building & Construction 4 12-26-2008 04:16 PM
Best way to flatten/level existing ceiling framing? RolandOG Building & Construction 20 10-13-2008 07:28 PM
Framing on concrete subfloor blschmitz Building & Construction 4 11-29-2007 07:53 AM
