Framing Around Ductwork - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 12:41 PM   #1
I have new ductwork from the floor in my garage to the ceiling and I want to finish around it. The garage is finished with drywall except the bottom which as concrete blocks. If I frame all the way to the floor, how can I keep the bottom of the drywall from corroding? Is there another way to finish it so that it matches the the garage? Please see pic.
SK McGuire is offline   Reply With Quote
Old 08-08-2009, 12:57 PM   #2
What if you box around the duct and then put a piece of 1/4" plywood around the bottom of the board. It won't be exactly what you have now, but you should be able to paint the plywood to match the color of the exposed cinder blocks you currently have. Unless you go and touch it, probably wont know its painted wood.
Green Giant is offline   Reply With Quote
Old 08-08-2009, 01:11 PM   #3
Registered User
Rewards Points: 526
http://www.lowes.com/lowes/lkn?actio...8-34299-220023
Be safe, G
Old 08-08-2009, 04:09 PM   #4
Git
Looks like someone got lazy - is there a reason why that duct could not have been run INSIDE the wall?
To be safe, I would use pressure treated lumber for the bottom plate, and then run the new drywall so there is about 1/2 to 3/4 " gap above the floor. Then use a baseboard to cover it up
Git is offline   Reply With Quote
framing around ductwork jcrampton Remodeling 12 08-01-2011 02:31 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Framing around ductwork - large span Erly Building & Construction 1 05-20-2009 12:15 PM
Support Framing Around Ductwork mfleming Building & Construction 4 12-04-2008 01:45 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
