Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-06-2010, 07:17 PM   #1
Framing
How do I build a wood wall on an uneven concrete floor. This is in a basement in a house over 100 years old.
emily cruze is offline   Reply With Quote
Old 09-06-2010, 07:56 PM   #2
Rewards Points: 558
Here is a link on what to do: http://www.basements101.com/framing2.html
Itís much easier to show you then explaining it.
epson is offline   Reply With Quote
Old 09-07-2010, 01:33 AM   #3
Rewards Points: 1,188
Very slowly; not to be a smarty pants, but an uneven floor is a PITA. You'll either have to level it w/ concrete leveler, or the like, or perhaps build smaller sections of wall of different lengths, if the floor is that bad. Plywood shims may help, too, Epoxy'd to the floor. I don't think there is any easy way for you.
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
framing material estimate maydoug Building & Construction 38 06-12-2009 01:32 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 09:27 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
