Frame/support Deck Around Downspout And Sump Discharge - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By jlhaslip
  • 1 Post By SeniorSitizen
Old 05-12-2017, 04:23 PM   #1
Rewards Points: 1,524
Frame/support deck around downspout and sump discharge
Yes another deck post from me... Getting ready to submit for the permit on this thing...
I am building a freestanding 18x6 deck 11" from grade.. plain old rectangle. It is going up against a wall that has a downspout and sump discharge that I need to frame around. Looking for advice on how I need to frame/support the deck around these things to meet code.. My city follows the IRC.
The colored rectangle in the image below is where the downspout and sump are.. Circles are the concrete piers.. The obstructions stick out about 5.5 inches from the wall..
Do I have to add support under the areas right next to the downspouts?
Thanks...
Frame/support deck around downspout and sump discharge-plan.jpg
ryansdiydad is offline   Reply With Quote
Old 05-12-2017, 05:36 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Frame/support deck around downspout and sump discharge
You should be able to bulkhead each side of the piping and then run another piece close to the end of the deck boards and be okay.
As per below. A red H indicates Hanger.
Frame/support deck around downspout and sump discharge-deltacad-sheet1-.jpg
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 05-12-2017, 05:48 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 254
I guess I'm missing something. I can't read any of the details from your drawing - maybe it's my monitor. Can the downspout be re-directed away from the deck? Any time I have seen a downspout accommodated at a deck they simply cut that deck board short. Are the left and right headers a ladder to accommodate 'picture frame'deck boards? Are you saying that the deck framing or header will interfere with where the sump discharge emerges from the foundation?
lenaitch is offline   Reply With Quote
Old 05-12-2017, 06:02 PM   #4
If you save the image you can zoom in.
But yes the downspout and discharge are tight up against the house exterior. I cannot run any framing between the downspout or sump discharge and the house. If I really really really had to I think I could possibly move the downspout and discharge away from the house by 1.5" but both of these are connected to an in ground storm sewer line so I would need to dig up cut/move/re-attach the inground pipes and then extend the sump and downspout out..
I'll get you a picture of the two of them..
And the ladder is to support the picture frame..
Old 05-12-2017, 06:14 PM   #5
Pic of obstructions
Frame/support deck around downspout and sump discharge-img_0291.jpg
The Following User Says Thank You to ryansdiydad For This Useful Post:
myjunkyard (05-14-2017)
Old 05-12-2017, 06:46 PM   #6
jlhaslip's Avatar
Rewards Points: 708
I changed my image to better suit your application.
Frame/support deck around downspout and sump discharge-deltacad-sheet1-_3.jpg
lenaitch likes this.
Old 05-12-2017, 07:07 PM   #7
Do I not need any support under those 2 corners kind of hanging out there ? Or is that span about 5" or so ok to just leave dangling?
In your drawing how is any of that kept from just sagging?
Old 05-12-2017, 07:57 PM   #8
jlhaslip's Avatar
Rewards Points: 708
The piece which is "split" attaches to the house, no?
Old 05-12-2017, 08:02 PM   #9
no this is a freestanding deck...
Old 05-12-2017, 08:04 PM   #10
jlhaslip's Avatar
Rewards Points: 708
Oops!
Then you need to place a full length joist as close to the pipes as you can and shoot the decking long.
Old 05-12-2017, 08:20 PM   #11
Rewards Points: 2,624
Oops!
That's how I did ours and IIR the joist next to the house is 8 or 10 inches away. No one ever seems to want to walk that close to the house and it has worked well.
jlhaslip likes this.
Old 05-12-2017, 08:50 PM   #12
Oops!
Problem is that area is supposed to be where the picture frame goes.. those boards run parallel to the joists...
Old 05-12-2017, 09:24 PM   #13
jlhaslip's Avatar
Rewards Points: 708
Mount a double joist under the floor system hung off the Beams at the closest position next to the pipes.
Do a change of direction joist system from the wall to the second last full length joist which you double up to take the weight of the change of direction stuff.
These short joists would be hung off the full length double joist and rest on the flush beam.
Fill in blocks on top of the flush beam to carry the decking ends.
I can draw it up later. No time right now.
Underground downspout questions garrett1812 Landscaping & Lawn Care 7 04-23-2016 09:42 AM
Proper way to bury sump pump discharge line? word2yamutha Plumbing 9 06-16-2014 08:18 AM
Sump pump drain into buried downspouts Chokingdogs Plumbing 1 11-07-2012 12:09 PM
Should I add a downspout? scottyv81 Roofing/Siding 5 05-09-2012 08:37 PM
Sump Pump french drainage issue HomeDIYslfr Plumbing 1 05-16-2009 01:21 PM
