Foundation Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 12:00 PM   #1
Foundation Wall
We have a dug well behind our cottage, and are going to tear down and rebuild a new home, this time with a basement, instead of a crawl space. Right now the well is 6 feet from the cottage foundation, which is only at best 2 courses of concrete block built on sand. Old school cottage style. Funny thing is, even though it's well above the frost line (we're on Georgian Bay ), it's never heaved or cracked. My handy man neighbour says it's because it's built on sand. The sand wicks the water away, so it can't freeze and do damage. Does this make sense.?
How close to the well can we pour footings? I know we want unexcavated soil, and obviously the well was "dug". The well is 4 feet diameter, and is made of pre cast concrete sections, and is aout 15 feet deep. The water table is just below where we would need to pour footings, to enable us to have a 7 foot basment. Any advice?
Bozco's is offline   Reply With Quote
Old 12-05-2010, 02:09 PM   #2
Rewards Points: 5,348
I would get the advice of a Soil Engineer before you start digging. If the soil has a heavy sand component, it won't be too stable. Guessing at the proper distance could easily cause issues with the well. Or you could just drill a new well and put the house where you want.
Ron
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
Foundation or Load Bearing Wall Issue? sheribaby Building & Construction 3 04-14-2010 05:07 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Free standing block wall foundation 3DPiper Building & Construction 4 10-19-2006 08:42 PM
