Thread Tools | Display Modes |
#1 |
Rewards Points: 80
![]() Foundation sill
Hi, My foundation sill has big gaps on the bottom and top of it. It's not like that on one side if the house but is where u can see in another side. I can see all the way till some cement debris I don't know what it would be maybe you can help. Should I insulate and call or wedge some wood in between to close it? I can feel a draft coming through the pipe so can I just call the pipe and where the two sills meet in the corner. Should I just calk any small holes or insulate then calk if u can? Thanks
Sponsored Links | |||
Advertisement |
#2 |
Rewards Points: 1,466
![]() Re: Foundation sill
Easiest, great stuff foam. End of story.
Nealtw likes this.
Advertisement |
#3 |
Rewards Points: 16
Are any of your rim joist insulated? If not look at Froth-Pak. Not the cheapest stuff but if your in Canada I would assume it would pay for it self in a few years. And keep some bugs out.
Sent from my SM-G960U using Tapatalk Last edited by spitz1234; 01-15-2019 at 10:58 PM. |
Advertisement |
#4 |
Rewards Points: 7,096
Hi Bren,
That first picture looks like there has been a moisture issue. Determine what the cause is and fix, if it hasn't already been done. At some point some wood there may need to be replaced. Closed cell can foam doesn't always look that good a few years down the road, but it is quick and easy. Technically you need to check local authorities to see if they want a foam job covered by a thermal barrier. Some do dome don't. Highest priority will be air sealing. If you go with the can foam rig up a longer tube so you can apply the foam with the can vertical from a little farther away. I found some plastic tubing that was a tight fit to their straw. Also notices they have a tip of some sort on their straw last time I purchased. Snip and it was gone. I have used a lot of construction adhesive, less expensive, large tubes. And when dried solid as a rock. Loctite pro line was the last I bought. Rope caulk can also help as it can be pushed into difficult places. Point being seal everything. Once sealed you could fill the cavities with Roxul. Not sure if you have anything on the foundation walls or not but at last the top half needs to be insulated. Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information. |
#5 | |
Rewards Points: 80
![]() Re: Foundation sillQuote:
Ok so what you are saying is calk as far as I can to the other side of gap, insulate and then finish by calling the gap to the inside of the foundation? Just making sure thanks |
#6 |
Rewards Points: 80
Seems easy enough and just fill the whole cavity? Do I have to worry about insects or rodents? Thanks
#7 |
Filling a cavity with can foam isn't all that easy. It is designed to deliver a bead of foam rather than a spray. The high expanding foam will expand all over if you don't know when to stop. Even the next day. And it can only be applied so thick or the interior will never cure. Oh and did I mention foam doesn't like cold temperatures. Ironically it does like moisture so read up on spraying a touch of water to the surfaces before applying.
The froth pack mentioned is a spray variety which if you have enough area to justify might work out. Still need to address the thermal barrier question. What I was explaining was, seal the leaks and then stuff the cavities with Roxul. No need for more caulking. Bud
#8 | |
retired framer
Rewards Points: 1,584
Bud9051 likes this.
#9 |
I'm not fully awake as yet
Bud
#10 | |
Rewards Points: 80
Also, it wouldn't be as effective because of the insulation factor correct like in spray foam? Also it says not to use any of the foam if not in the desired temperature range. What should I do in that case? Thanks |
#11 |
Air sealing is a big factor in reducing heat loss. After it is air sealed the temp will improve so some can foam can be used, but best if you wait for warm weather.
Sealing the rim joist cavities and the rim to the foundation is all infiltration. Cold air pushes in the lower areas and forces warm air up and out the high areas. Cutting pieces of rigid foam to fit loosely into each joist cavity and then sealing the perimeter with either caulking or can foam is another alternative. Bud Nealtw likes this.
The Following User Says Thank You to Bud9051 For This Useful Post: |
Bren24 (01-28-2019)
Advertisement |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
What can I cover foundation with?? | prosper50 | Concrete, Stone & Masonry | 14 | 09-24-2015 01:14 PM |
Spray foam between sill plate and foundation? | jimcrook | Insulation | 1 | 10-21-2014 03:38 PM |
Foundation anchor bolts and sill plate question | dwoloz | Building & Construction | 7 | 05-17-2011 08:17 AM |
What to use for foundation anchor to sill? | axiom10 | Building & Construction | 1 | 04-21-2010 11:57 AM |
Replacing Termite Damaged Sill, Joists, and Girders | bd_dc | Building & Construction | 0 | 02-02-2010 12:21 AM |
