Foundation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 10:03 PM   #1
foundation question
Question: Concrete footers with simpson anchors for 6x6 attatchment, or 6x6 set on gravel base and then backfilled with gravel. Foundation is for 2400 sq' home with 12' porch all around. Uplift will be a concern
Dereck is offline   Reply With Quote
Old 01-04-2010, 10:09 PM   #2
concretemasonry's Avatar
Rewards Points: 2,716
Where are you? - More details will help.
What does the designer require for the home?
With any real wind, it will be difficult to provide anchorage without some substantial mass below grade.
concretemasonry is offline   Reply With Quote
Old 01-05-2010, 06:26 AM   #3
Might work for the tropics, would never work here, mid atlantic. Frostline is 30"
Old 01-08-2010, 05:49 PM   #4
hey concretemasonry, I am located in southern illinois. frostline is 20" around here. I was wondering if 6x6 could be set in concretre if i wrapped in a poly barrier or wrapped in expansion joint material. i have built many buildings but not here, recently moved here from florida and this area is nothing i am used to.
Old 01-08-2010, 05:55 PM   #5
also what about camfer cutting the corners of the 6x6 to allow for drainage?? would this be possible?? i have very good drainage here, sit on top of a hillside that runs down to a bottom, probably 30' elevation change in good clay soil
Old 01-08-2010, 06:00 PM   #6
thats alot of posts and healthy footings for that size
Old 01-08-2010, 06:05 PM   #7
Yeah i had it figured at 42 posts and footers just for the house part not including the porches
Old 01-08-2010, 06:06 PM   #8
Am i crazy for this idea, should i proceed or regroup and go with a traditional stem wall footer combo
Old 01-08-2010, 06:15 PM   #9
I would price poured walls vs footing w/ block vs posts w/ footing and your labor
Re-grading around foundation? robertr4836 Landscaping & Lawn Care 10 05-23-2009 05:34 PM
Foundation question mrmarkyt Building & Construction 6 03-23-2009 08:53 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Foundation movement question kelly001 Building & Construction 5 10-02-2006 06:09 AM
re-enforcing foundation - southern cal jhb Building & Construction 1 10-02-2006 12:15 AM
