Foundation Problem? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2009, 08:09 PM   #1
foundation problem?
Hi I'm having a problem with my kitchen floor, there is a noticeable hump in the middle of the floor. I went under the house and all the joists seem to be fairly level, but there was about a 3/4 gap in my foundation slab. The block seems to be okay. I live at the base of a hill and get a lot of water run off. So I'm thinking that the water is maybe causing the foundation to drop.(It stays pretty soft under that part of the house.) Could my foundation cause the floor problem, and is that an expensive fix? I'm going to try to put in a french drain to try to catch the water and displace it some where else. Any ideas what else I need to do?
Thanks for any and all help.
Waverly Guy
waverly guy is offline   Reply With Quote
Old 06-08-2009, 06:09 AM   #2
Pics would help us, but I would advise having a professional look at the problem. it could be bigger than you think.
Phone Jack Hookup Problem kennykenny Electrical 21 04-09-2017 10:36 AM
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 02:46 PM
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 03:55 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
Addition Foundation /Build. advice wannabuild Remodeling 3 12-15-2006 06:28 PM
