Foundation Cracks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 11:27 AM   #1
Foundation cracks
I'm new here. I've been living in this house for 3 years. When I bought it there was many recent renovations done to it. I'm quite happy with it. The main issue I'm having is there is a crack in the otherwise solid foundation. This was caused by a front step that had sunk and pulled the rebar causing the crack. I have since removed the stairs. It has been patched and sealed from the inside. Now I'm looking for sugestions on how to go about fixing the out side in the summer. I only get a small amount of water during the spring thaw and after a heavy rain. Any sugestions from other members would be greatly apprieciated. Don
arrows1965 is offline   Reply With Quote
Old 03-18-2011, 11:41 AM   #2
the Musigician
DangerMouse's Avatar
Hello and welcome to the forum.
I took the liberty of moving this to the appropriate sub-forum.
You'll likely get very little help asking questions in the Introductions section.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
arrows1965 (03-18-2011)
Old 03-18-2011, 12:59 PM   #3
Rewards Points: 2,516
I think most will want a picture or two to illustrate where, how big, relation to the leaking area, etc...
bob22 is offline   Reply With Quote
Old 03-18-2011, 01:02 PM   #4
Experienced
Jackofall1's Avatar
Rewards Points: 2,108
Hi and Welcome Don, to the best DIY'r site on the web.
Pictures are worth a thousand words, and usually generate your best answers.
Mark
Old 03-18-2011, 01:48 PM   #5
Once I figure out how to post pictures I will.
Old 03-18-2011, 02:15 PM   #6
the Musigician
http://www.diychatroom.com/f98/how-a...to-post-20532/
Po)
DM
Cement cracks in foundation after water damage Ginette Building & Construction 4 09-06-2010 07:14 PM
How to Repair Cinder Block Foundation Cracks Germwise Building & Construction 4 07-01-2010 12:14 PM
Foundation cracks drain tile fiveoh018 Plumbing 3 06-26-2010 03:55 PM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 10:48 PM
Cracks in foundation....leaks....need some info. wackerjr Building & Construction 5 06-12-2006 02:15 PM
