Foundation In Cold Weather - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Nealtw
  • 1 Post By Marson
Old 11-10-2018, 08:36 PM   #1
Rewards Points: 618
Foundation in cold weather
Someone said I should wait until spring. That it's not worth it.
Weather forecast will be high 20's in the morning up to 50 during the day. No snow. Mornings are cold.
Any input will be greatly appreciated.
Richard Pryor is offline   Reply With Quote
Old 11-10-2018, 08:58 PM   #2
retired framer
Rewards Points: 14,634
Re: Foundation in cold weather
Our concrete plants shut down at a certain temp just above freezing and if we do pour and expect freezing we rent thermal blanket for the foundation to keep the heat in over night.
Richard Pryor likes this.
Old 11-10-2018, 09:57 PM   #3
Rewards Points: 926
Depends on how urgent the job really is. Around here, crete is more expensive as suppliers have to run heaters. You could wait for a better window. Personally, because foundations are permanent structures, I try to push them to the most ideal conditions so the best outcome is possible. I think about the workers. Happy and comfortable workers will do a better job, not rush and screw it up. On something like a municipal bridge project, arrangements are made to get it done. This can mean tuning the crete blend, heaters, you name it.
Are we talking a footing or full basement foundation walls?
Depending on size, something I have done is a temp wood structure within a pit to lay a thermal blanket on, and propane heaters in the space. The crete will produce heat and the earth will be constantly supplying heat so just trapping that is a big help.
viper is offline   Reply With Quote
Old 11-11-2018, 09:44 AM   #4
Rewards Points: 928
Gee, that temp not a problem at all provided you can get concrete. Especially for footings or foundation. I used to pour in the winter in Duluth MN and for flat work our cut off HIGH temperature for the day was 20 above (below that and we called it off). That's high temperature. Footings and foundations could be poured in any weather provided the dirt underneath isn't frozen. The concrete gets covered with insulated tarps. It generates it's own heat, so even in sub zero F weather, the next morning the pour will be quite warm. You will need to keep it covered for 48 hours before you can let it freeze. I'd call your local ready mix company and see what they have to say. They will know the ins and outs. Here in the frozen north heated water and accelerators are standard procedure in the winter.
Nealtw likes this.
Marson is offline   Reply With Quote
The Following User Says Thank You to Marson For This Useful Post:
jomama45 (11-12-2018)
Old 11-11-2018, 09:57 AM   #5
retired framer
We work in the rain up here but we don't do well in the cold. I don't think the plants are set up for cold weather, in 20 years we only had to put off 2 or 3 jobs and only did 2 that had to be kept warm.
Old 11-11-2018, 04:22 PM   #6
Contractor/Engineer
Rewards Points: 1,084
Ask you concrete supplier. He knows what to add to the concrete mix and how to help it cure properly in low ambient conditions.
Domo is offline   Reply With Quote
Old 11-11-2018, 05:48 PM   #7
HenryMac's Avatar
Rewards Points: 814
Be really careful. Many concrete contractors will tell you they know all there is to know... when in reality they don't. They simply want your job done and your money in their hand so they can move on to the next site.
https://www.cement.org/learn/concret...her-concreting
HenryMac is offline   Reply With Quote
Large Piece of Concrete broke off of Foundation After Freeze/Thaw in Cold Weather km782 Concrete, Stone & Masonry 8 01-25-2018 07:27 AM
Stone foundation repair in Philadelphia cb_philadelphia Concrete, Stone & Masonry 1 11-03-2016 02:39 PM
Outback Remote Fails in Cold Weather Jazan Automotive Repairs 6 03-02-2015 04:58 PM
Foundation Issue - House Heaves in Cold Weather Lewes Building & Construction 1 10-12-2010 09:20 PM
PVC pipe & cold weather Bernmeister Plumbing 4 01-11-2010 11:37 AM
