Footing For Column - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-08-2008, 08:58 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,932
Footing for Column
I need to add a column in the basement for reconfigured staircase and floor space above. what size area should I cut out from the basement floor and how deep should the footing be?
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 11-08-2008, 09:11 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
All the column footings that I have put in over the years where all spec. out by the architects to be 2'x2'x1' . providing it is in a basement. Hope this was of some help. BOB
Old 11-08-2008, 09:21 AM   #3
I have gas!
Thanks, that helps. I want to sound like I know what I'm talking about when talking to the building inspector.
Old 11-08-2008, 10:00 AM   #4
Super Moderator
joed's Avatar
Rewards Points: 30,472
The size is entirely dependant on what it will be holding up.
Old 11-08-2008, 11:18 AM   #5
concretemasonry's Avatar
Rewards Points: 2,716
The size also depend on what is under it (quality of soil). That is why is is a spread footing to spread the load from above out. - Bad soil or loose clay means a bigger footing.
If you are lucky ($-wise), you will get a dumb inspector that will accept the prescriptive standards and not have enough sense to ask for a signed design. That may not be the best in the long run.
concretemasonry is offline   Reply With Quote
Old 11-08-2008, 01:30 PM   #6
bob, joe, & dick're all right,,, our footings're always 1'0 deep but include 2 mats of #5 bar - usually 3'0x3'0 in local soils,,, spread footings're common, too,,, need to know how much is above AND will the soil handle the static AND dynamic load.
IF there's ANY question, having a pro engineer stamp'd design's cheap insurance - i trust those guys MUCH more'n the avg municipal employee.
yesitsconcrete is offline   Reply With Quote
Old 11-08-2008, 02:59 PM   #7
I have gas!
I'm not trying to get out of doing the right thing but I'm also not too worried about the load. It's a small floor section I'm supporting. With our new double turning staircase, I need to support 2 sections of floor of that are 3x8'. So using a standard 10/40 load with tributary of 4' and 40lbs/linear foot for wall with a tributary of 5.5' the total weight on the post will be 1440 lbs.
Old 11-08-2008, 04:29 PM   #8
Registered User
Termite's Avatar
If I were you I'd ask the inspector if they'd be ok with a 24x24x12" pad with two mats of bars 6"oc each way. Personally, I'd make you get an engineer to specify it, but your inspector might be "nicer" than I am.
footing drain question chrisk Building & Construction 2 09-02-2007 08:21 PM
How level does a footing need to be? tripower Building & Construction 1 05-03-2007 09:59 AM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 03:22 PM
New addition old footing problem meashmut Building & Construction 2 04-20-2006 07:03 PM
